Changing from PORTC to PORTA Problems
Results 1 to 10 of 10
    Hangover, Germany
    Hello,
    the complicated way:
    MaskSwitch=(PortC & %00000111) | ((PortC & %11000000) >> 3) | ((PortA.0 & %00000001) << 5)
    The better way (using the bit-operators of PICs):
    MaskSwitch=0
    If PortC.0 Then MaskSwitch.0=1
    If PortC.1 Then MaskSwitch.1=1
    If PortC.2 Then MaskSwitch.2=1
    If PortC.6 Then MaskSwitch.3=1
    If PortC.7 Then MaskSwitch.4=1
    If PortA.0 Then MaskSwitch.5=1
    Check out the size !!!
    But be aware to press more then ONE key !!!
    Then you have to write multiple case-lines !!! ;-)
    Feb 2005
    Essex, UK
    OK, So the second options is still using the CASE SELECT method is it?
    Does this mean that the statement will look as follows:
    Button1      Var PORTC.0
    Button2      Var PORTC.1
    Button3      Var PORTC.2
    Button4      Var PORTC.6
        MaskSwitch=0
        If PORTC.0 Then MaskSwitch.0=1
        If PORTC.1 Then MaskSwitch.1=1
        If PORTC.2 Then MaskSwitch.2=1
        If PORTC.6 Then MaskSwitch.3=1
            Select Case MaskSwitch
              Case 0
                If Button1 = 1 Then Gosub Procedure_Button1
                If Button1 = 0 THEN
                EndIf
              Case 1
                If Button2 = 1 Then Gosub Procedure_Button2
                If Button2 = 0 THEN
                EndIf
              Case 2
                If Button3 = 1 Then Gosub Procedure_Button3
                If Button3 = 0 THEN
                EndIf
    ie, does the MaskSwitch.1 represent Case 1 value, MaskSwitch.2 represent Case 2 etc etc?
    Many thanks again,
    Hangover, Germany
    No,
    like your first posting, the maskswitch is:
    1, 2, 4, 8, 16, 32 ....
    or binary:
    %00000001, %00000010, %00000100, %00001000, ...
    Hangover, Germany
    ...and:
    why are you checking the buttons inside the case-staments, when the case-statements are only executed, if the Buttons are pressed ?
    Do you think, this will be the optimal way ?
    After programming several decades in assembler, i think it is better, to check the Port-Bits and call the subroutines...
  1. MY FIRST scrolling 8X8 LED
    Last Post: - 15th August 2008, 17:23
  2. How do I configure the PIC16F737?
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 19th November 2007, 00:05
  3. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 02:31
  4. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
  5. PORTA problems 18LF252
    By iphillips in forum mel PIC BASIC Pro
    Last Post: - 28th February 2005, 14:56
