Thanks for you help BigWumpus. I wanted to avoid using multiple IF..THEN statements as the 'cleaner' way is supposed to be using a CASE SELECT.
However, this is where i fall down. I am having difficulty using the CASE SELECT with multiple PORTS.
Obvioulsy if it can't be done then i have the multiple IF...THENS but i think with 5 or 6 buttons (or HIGH inputs as they will be), the code will be much bigger then using a structured CASE SELECT.
Cheers,
