Changing from PORTC to PORTA Problems
Results 1 to 10 of 10
    Feb 2005
    Essex, UK
    Second thoughts.....is there a way to use the Case Select option as above for PORTC.0-2 (as it currently is) for the first 3 switched inputs, but then use PORTB.0-2 for the remainding 3 swtched inputs?
    I am still new to using Case Selects so it is a bit confusing.
    Many thanks.
    Hangover, Germany
    You must switch PortA to digital-I/O, after a Reset it will be only analog-in !
    Just see the docs !
    Feb 2005
    Essex, UK
    Thanks BigWumpus, i tried this, but still no luck.
    Ideally i want to monitor lines RC0, RC1, RC2, RC6, RC7 and RA0 (can't use RC3 as there isn't one and RC4 & 5 are used for USB. When a switch is depressed on one of theses lines it jumps to a corresponding sub routine.
    I've got the Case Select routine working for RC0-2 but am struggling with the rest, particulalry as it loks at a different PORT.
    Can anyone help please?
    Hangover, Germany
    Check the documentation around ADCON1 to switch PortA from analog to digital.
    Your Case-statement looks fine, but is very very big in code !
    (You have to calculate the MaskSwitch out of 2 numbers!)
    Whats about this:
    Button1 Var PortC.0
    Button2 Var PortC.1
    Button7 Var PortA.0
    ADCON1=%00001111
    If Button1 Then
    If Circle = 1 Then Gosub Procedure_Circle
    Endif
    If Button2 Then
    If ...
    Endif
    Feb 2005
    Essex, UK
    Thanks for you help BigWumpus. I wanted to avoid using multiple IF..THEN statements as the 'cleaner' way is supposed to be using a CASE SELECT.
    However, this is where i fall down. I am having difficulty using the CASE SELECT with multiple PORTS.
    Obvioulsy if it can't be done then i have the multiple IF...THENS but i think with 5 or 6 buttons (or HIGH inputs as they will be), the code will be much bigger then using a structured CASE SELECT.
    Cheers,
    Hangover, Germany
    Hello,
    the complicated way:
    MaskSwitch=(PortC & %00000111) | ((PortC & %11000000) >> 3) | ((PortA.0 & %00000001) << 5)
    The better way (using the bit-operators of PICs):
    MaskSwitch=0
    If PortC.0 Then MaskSwitch.0=1
    If PortC.1 Then MaskSwitch.1=1
    If PortC.2 Then MaskSwitch.2=1
    If PortC.6 Then MaskSwitch.3=1
    If PortC.7 Then MaskSwitch.4=1
    If PortA.0 Then MaskSwitch.5=1
    Check out the size !!!
    But be aware to press more then ONE key !!!
    Then you have to write multiple case-lines !!! ;-)
    Feb 2005
    Essex, UK
    OK, So the second options is still using the CASE SELECT method is it?
    Does this mean that the statement will look as follows:
    Button1      Var PORTC.0
    Button2      Var PORTC.1
    Button3      Var PORTC.2
    Button4      Var PORTC.6
        MaskSwitch=0
        If PORTC.0 Then MaskSwitch.0=1
        If PORTC.1 Then MaskSwitch.1=1
        If PORTC.2 Then MaskSwitch.2=1
        If PORTC.6 Then MaskSwitch.3=1
            Select Case MaskSwitch
              Case 0
                If Button1 = 1 Then Gosub Procedure_Button1
                If Button1 = 0 THEN
                EndIf
              Case 1
                If Button2 = 1 Then Gosub Procedure_Button2
                If Button2 = 0 THEN
                EndIf
              Case 2
                If Button3 = 1 Then Gosub Procedure_Button3
                If Button3 = 0 THEN
                EndIf
    ie, does the MaskSwitch.1 represent Case 1 value, MaskSwitch.2 represent Case 2 etc etc?
    Many thanks again,
  1. MY FIRST scrolling 8X8 LED
    Last Post: - 15th August 2008, 17:23
  2. How do I configure the PIC16F737?
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 19th November 2007, 00:05
  3. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 02:31
  4. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
  5. PORTA problems 18LF252
    By iphillips in forum mel PIC BASIC Pro
    Last Post: - 28th February 2005, 14:56
