Changing from PORTC to PORTA Problems
Results 1 to 10 of 10
    Feb 2005
    Essex, UK
    Default Changing from PORTC to PORTA Problems
    I was using PORTC as inputs for switches, but as it appears that the PIC18F2550 has no PORTC.3, i've to to move all to PORTA. However, after changing all the PORTC in code to PORTA, the PIC doesn't perform correctly.
    Am i missing something?
    This is what i had.
    ' ---------- [ I/O Definition ] ----------
    TRISA = %11111111       ' Set PORTA to all input
    TRISB = %10000001       ' Set PORTB (0)INPUT (1-5)OUTPUTS
    TRISC = %00000111       ' Set PORTC (0-2 input) rest Outputs
    ' ---------- [ System Inputs ] ----------
    Circle      Var PORTC.0         ' 1 - Circle Switch
        MaskSwitch=PORTC & $07
            Select Case MaskSwitch
              Case 1 '%00000001 or Circle Switch
                If Circle = 1 Then Gosub Procedure_Circle
                If Circle = 0 THEN
                EndIf
    Which i thought i'd simply changed to-
    Circle      Var PORTA.0         ' 1 - Circle Switch
        MaskSwitch=PORTA & $07
                If Circle = 0 THEN
                EndIf
    Thank you,
    Feb 2005
    Essex, UK
    Second thoughts.....is there a way to use the Case Select option as above for PORTC.0-2 (as it currently is) for the first 3 switched inputs, but then use PORTB.0-2 for the remainding 3 swtched inputs?
    I am still new to using Case Selects so it is a bit confusing.
    Many thanks.
    Hangover, Germany
    You must switch PortA to digital-I/O, after a Reset it will be only analog-in !
    Just see the docs !
    Feb 2005
    Essex, UK
    Thanks BigWumpus, i tried this, but still no luck.
    Ideally i want to monitor lines RC0, RC1, RC2, RC6, RC7 and RA0 (can't use RC3 as there isn't one and RC4 & 5 are used for USB. When a switch is depressed on one of theses lines it jumps to a corresponding sub routine.
    I've got the Case Select routine working for RC0-2 but am struggling with the rest, particulalry as it loks at a different PORT.
    Can anyone help please?
    Hangover, Germany
    Check the documentation around ADCON1 to switch PortA from analog to digital.
    Your Case-statement looks fine, but is very very big in code !
    (You have to calculate the MaskSwitch out of 2 numbers!)
    Whats about this:
    Button1 Var PortC.0
    Button2 Var PortC.1
    Button7 Var PortA.0
    ADCON1=%00001111
    If Button1 Then
    Endif
    If Button2 Then
    If ...
    Endif
    Feb 2005
    Essex, UK
    Thanks for you help BigWumpus. I wanted to avoid using multiple IF..THEN statements as the 'cleaner' way is supposed to be using a CASE SELECT.
    However, this is where i fall down. I am having difficulty using the CASE SELECT with multiple PORTS.
    Obvioulsy if it can't be done then i have the multiple IF...THENS but i think with 5 or 6 buttons (or HIGH inputs as they will be), the code will be much bigger then using a structured CASE SELECT.
    Cheers,
  1. MY FIRST scrolling 8X8 LED
    Last Post: - 15th August 2008, 17:23
  2. How do I configure the PIC16F737?
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 19th November 2007, 00:05
  3. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 02:31
  4. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
  5. PORTA problems 18LF252
    By iphillips in forum mel PIC BASIC Pro
    Last Post: - 28th February 2005, 14:56
