Compiling for the 18F252, you can't use the MPASM !!!!!!!
The error occurs, because you are using numbers (or calculations) which are bigger then 16 Bits !
Check your source (or look in your .lst-file for the error) for this big number.
BigWumpus thank you for your help. I found the error and it works just fine now. It was my sampling rate and it was set for like 99000. I must have edited my code after a late night at the bar. I hate those errors that are vague and send you looking in all the wrong places.
