PBP2.46, MPLAB and PM assembler.
Results 1 to 12 of 12
    Hi, Mel
    Thank you for the answer.
    Limiting The file name to 8 Characters doesn't change the result .
    You'll laugh : I run Win XP Home ... and was hard to find how to run in DOS Mode !!! ... with W98 SE, it was easy to call for pure DOS ...
    Alas ... Result is exactly the same ...
    More examples :
    MPASM ... with the "putmulresult" macro ( THE reason to use PM ...)
    Executing: "C:\Program Files\Microchip\MPLAB IDE\PBP\PBPW.EXE" -ampasmwin -oq -z -v -p16F628 "Acetachy.bas"
    PicBasic Pro Compiler 2.46, (c) 1998, 2005 microEngineering Labs, Inc.
    All Rights Reserved.
    Pass 1:
    Pass 2:
    Code Gen:
    Macro Pass:
    mpasmwin /q "C:\Program Files\Microchip\MPLAB IDE\Projets\Acetachy.ASM"
    COD Pass:
    Warning[207] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\ACETACHY.ASM 430 : Found label after column 1. (putmulresult)
    Error[108] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\ACETACHY.ASM 430 : Illegal character (6)
    Loaded C:\Program Files\Microchip\MPLAB IDE\Projets\Acetachy.COD.
    BUILD SUCCEEDED: Wed Dec 07 14:27:18 2005
    Note : line 430 is :
    ASM?
    putmulresult 60000000
    ENDASM?
    with PM
    Executing: "C:\Program Files\Microchip\MPLAB IDE\PBP\PBPW.EXE" -v -p16F628 "Acetachy.bas"
    Pass 1:
    Pass 2:
    Code Gen:
    Macro Pass:
    PM.EXE C:\PROGRA~1\MICROC~1\MPLABI~2\Projets\Acetachy.ASM
    ERROR: Unable to execute PM.EXE.Halting build on first failure as requested.
    BUILD FAILED: Wed Dec 07 14:36:37 2005
    ... any other idea ???
    Let's first eradicate corrupt files and path name incompatability...
    Have you sucessfully compiled a simple blink led program with PM?
    If yes, then it's something in your main program body... comment out the possible offending line and see if it compiles... time to start narrowing down what's causing the error.
    Wink The long and winding road ....
    Hi, Mel
    All my programs refuse PM now ... they accepted it a while ago !!!
    I'll try a brand new simple project, as you suggest.
    Unhappy
    THAT
    Led var Portb.1
    Led = 0
    loop:
    Pause 5
    Toggle led
    Goto loop
    NOTE: PAUSE 5 for MPSim ... might be PAUSE 500
    Doesn't go either with PM ( MPlab sim runs OK ...) shame on me to have written that.
    For your Post ... Yesss, I did declare it for a time ... and it's Ok.
    May I cancel this stupid blinking led of shame ???
    Hi Alain,
    Doesn't help your problem, but I saw this line
    The "PutMulResult" macro works fine with MPASM too. No need for PM.
    Question Works well ???
    Quote Originally Posted by Darrel Taylor
    Hi Alain,
    Hi, Darrel
    As you could have read some lines further ...
    Do you call that working fine ???
    I don't even know if the code produced is correct ... but no Warning/Error with a 1k memory device like a 'C84 !!!
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. MPLAB ICE 2000 emulator pod
    By Wayne in forum Adverts
    Last Post: - 1st April 2009, 01:25
