PIC16F877 PORTA Input Issue
Results 1 to 8 of 8
    CCK,
    Are you sure it's not a 16F877A
    If it is, you'll also need   CMCON = 7
    It is actually the 877 and not the 877A. I thought the same thing at first until I double checked the actual chip. I did however since discover the issue. It has some to do with Bit7 for the ADCON1 register. I made it 1 instead of 0 and everything seems to work fine now. I don't understand why because the A/D is turned off for the justification I would not think would have any bearing on this matter but it seems to.
    Default What!
    You've GOT to be kidding!
    That's the strangest thing I've ever heard about PIC's.
    I use ADCON1=7 alot, and have never had to ADCON1=$87 for digital inputs. And, ADCON1=6 works well too.
    Is it repeatable? Changing ADCON1.7 back to 0, causes the same thing again?
    Well this makes no sense but I just checked it again with a 0 and it now works. I'm not sure what to make of this. Maybe I changed something else and forgot that I did that. Not sure what to make of it. It seems to work fine now
    ADCON1 = %00001111 is setting RA0 as A/D in, RA2 as -Vref & RA3 as +Vref.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    What does it mean when the datasheet says "Bit is unknown"? How do you make all the ports digital because the datasheet says 011x with x being an unknown?
    X in this case means it doesn't matter what the bit is. ADCON1 = %00000111 or ADCON1 = %00000110 will have the same effect.
    -Bruce
    tech at rentron.com
  1. PIC Interrupt and PORTA input
    By Jerade in forum mel PIC BASIC
    Last Post: - 29th November 2009, 18:24
  2. PortA digita input?
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 27th January 2009, 22:55
  3. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 23:06
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
