PicBasicPro, MPLAB IDE, and Win98SE
Results 1 to 9 of 9
    trying's Avatar
    trying Guest
    I used it before but now use xp but I think you may find help here
    http://www.microengineeringlabs.com/support/mplab.htm
    Windows 95/98/ME
    The search path is specified in a file called autoexec.bat, that should be located in the root directory of your C drive (C:\). You can edit the file with a text editor such as notepad, or run msconfig (Win98 only).
    The path statement uses the format: PATH=path1;path2;.... Add the paths to MPLAB and PICBASIC PRO to the end of the line, separating each path with a semicolon.
    An example path statement is: PATH=C:\WINDOWS;C:\PBP;C:\PROGRA~1\Microc~1\MPASMS ~1.
    Notice that long directory names must be shortened to their 8 character DOS equivalent. For example, the "Program Files" directory must be shortened to "Progra~1".
    Restart your computer after making changes to the autoexec.bat file.
    Default Problem Solved
    Okay, finally...programs are now compiling correctly in MPLAB IDE. Fixed with a path statement as suggested above; added into the autoexec.bat file, e.g. PATH=C:\WINDOWS;C:\PBP;C:\PROGRA~1\Microc~1\MPASMS ~1.
    It took a couple of tries to get the syntax right, but working now.
