pc cooling fan rpm monitoring
Results 1 to 3 of 3
    Perth, Australia
    Default pc cooling fan rpm monitoring
    does any1 know how the rpm monitoring pin works on pc cooling fans?
    I assume it will send a pulse either once per revolution or maybe 2 or 4 per revolution?
    i googled it but couldnt find info
    Perth, Australia
    found the info eventually after googling a while longer...
    for any1 who also wants to know, a pulse is generated twice per revolution, and its an open collector output so requires a 10k pull-up resistor for input to a PIC.
    Italy
    Wink
    Did you search for "cooling fan" on this forum?
    Luciano
  1. Computer Fan RPM Sensor Reading
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 27th December 2019, 21:05
  2. Interrupt RPM and Taylors Elapsed time on 18F4620
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2010, 17:12
  3. Pulsin vs. Interrupt RPM measurement
    By Tobias in forum General
    Last Post: - 31st December 2009, 02:29
  4. RPM - DIV32 Problem
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 11th April 2008, 05:33
  5. Code Issue - select case or 'if' issue - not sure why
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 7th October 2007, 09:52
