? on code
Results 1 to 11 of 11
Thread: ? on code
    Mar 2004
    I'm setting B.1 low with a 5k resistor to gnd. and high with wire inserted into breadboard.I'm sure the wire is far worse than a button. I had just tried this:
    i Var Byte
    Loop:
    If PortB.1=1 Then
    High PortB.0
    for i=1 to 60
    Pause 1000
    next
    Low PortB.0
    EndIf
    DoNothing:
    If PortB.1=1 Then
    Goto DoNothing
    EndiF
    low 0 }I added this
    pause 500 } "
    if portb.0=0 then} "
    Goto Loop
    I'm sure you're right about the "bounce" as this fixed the problem.
    I'll try your code instead though.
    The high to B.1 will actually come from an optoisolator in the final stage. I've got alot more code to figure out on this project and if you or anyone can recomend a book that would help,please do.
    Sam
    NavMicroSystems,I just sent you a PM.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
