MPLAB IDE Memory Gauge usage?
Results 1 to 5 of 5
    Question MPLAB IDE Memory Gauge usage?
    Hello,
    I would like to know, if possible, how to use the Memory Gauge of MPLAB?
    It needs the linker for the PIC, but I don't know how to use it with PBP.
    Any help will be greatly appreciate.
    Gabriel
    gabrielg74, Just look at the .lst file that is generated during the compile. At the end of the file is the total words used and total words remaining for flash memory. You can look at it with any text editor.
    Wink PBP Boycott ???
    Hi, gabriel
    Just "manually" import the .hex file obtained, into the program memory ... and you'll get that f... gauge working.
    It doesn't want to work starting from PBP.
    Acetronics,
    yes, this works fine. Easier than opening and scrolling the .lst file.
    Gabriel
    Wink PBP forever ...
    Hi, gabriel
    I remember using PM Assembler gives the number of lines too ... automatically, this time.
  1. picbasic pro and mplab IDE
    By soelinnhtet in forum mel PIC BASIC Pro
    Last Post: - 1st March 2010, 09:57
  2. Replies: 0
    Last Post: - 13th February 2009, 04:34
  3. Upgraded to MPLAB IDE 8.14 and now I'm stuck
    By BlueHairBob in forum General
    Last Post: - 20th August 2008, 02:15
  4. Using PICBASIC PRO in MPLAB IDE
    By jblackann in forum General
    Last Post: - 4th May 2008, 10:20
  5. "Program Memory Error" with MPLAB IDE (PBP)
    By aggie007 in forum mel PIC BASIC Pro
    Last Post: - 13th November 2007, 20:27
