micro code studio plus asm error
Results 1 to 8 of 8
    cesurcelik's Avatar
    cesurcelik Guest
    hi kamikaze47
    i solved that problem,but it's so weird; i thought that might've been the file name too long so i changed the file name "mat.bas" instead of "matrix_ser_den0".bas,i was right ,it's ok now!
    many thanks for your help.
    gwen's Avatar
    gwen Guest
    Hi, I noticed that any file name longer than 8 letter are not compiled. You have to chose short names.
    I had the same probleme few days ago.
    cheers
    Mentor, Ohio
    Smile
    Hello,
    I have using file names with 22 to 28 characters in length and have not any compiling problems.
    cesurcelik's Avatar
    cesurcelik Guest
    as i told that it's so weird! i can't explain that. i hope that someone explain it.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Making Program Code Space your playground...
  3. EPIC, Code programming error at 0000
    By shorton in forum General
    Last Post: - 29th May 2007, 01:26
  4. ASM (I am Working in ECU for Micro Turbines
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 29th January 2005, 02:00
  5. ASM Interrupts with BASIC code?
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 31st October 2003, 20:21
