How do you interface a 74hc165 to a pic12f629
Results 1 to 12 of 12
    orion1137's Avatar
    orion1137 Guest
    Question How do you interface a 74hc165 to a pic12f629
    Hello all im new to the pic basic so be easy on me. I am trying to interface a standard 74hc165 parallel to serial shift register to a pic 12f629 im using GPIO.0 as CLK OUT , GPIO.2 as the DATA INPUT pin and a push button to load the parallel inputs on the 74hc165 via the Serial Shift/ Parallel Load pin, I have a 8 bit dip switch connected to the parallel port of the 74hc165 with 4.7k pullups and ground when switch contact is closed. I have looked at the SERIN and HSERIN and just havent had any luck yet.
    Feb 2004
    Germany
    You need to use SHIFTIN.
    CMCON=7
    MyByte VAR Byte
    SHIFTIN GPIO.2,GPIO.0,0,[MyByte]
    I don't have a HC165 Datasheet available, make sure the mode matches the specs of the HC165.
    See PBP Manual Section 5.72
    orion1137's Avatar
    orion1137 Guest
    Smile Thanks !!
    Thank you!! Works like a charm. I got most of it from the Archives. Here is a cleaned up version.
    Low GPIO.0
    ' pin 1 of 74HC165 loads parallel port
    Pause 1
    High GPIO.0
    ' pin 1 of 74HC165 allow data to shift in
    ShiftIn GPIO.2,GPIO.1,0, [VAR1\8]
    'GPIO.2 to 74HC165 pin 9 and GPIO.1 to 74HC165 pin 2
    Pause 1
    "I got most of it from the Archives."
    Is this on this forum?
    I SEARCHed and could not find any other reference to 74HC165.
    I am particularly interested in how the 74HC165 is wired.
    "See PBP Manual Section 5.72"
    I get SERIN2 in my copy...? SHIFT IN is over at 5.75.
    :shrug:
    I have tried to interface a 16F628 with a 74HCT165 without success. I figured I should do a basic test to confirm that my code is working properly. I unplug the CK and PL pins and plug the Q7 pin on the PIC directly to power to test my code.
    - when I plug Q7 to GND, I get all 0s, as expected.
    - when I plug Q7 to +5V, I get all 0s and a 1 at the far right.
    This is my code:
    CMCON = 7
    LIST
    INCLUDE 'M16F62X.INC'
    DEVICE PIC16F628, HS_OSC, WDT_ON, MCLR_OFF, PWRT_ON, LVP_OFF, PROTECT_OFF
    XALL
    NOLIST
    INCLUDE "MODEDEFS.BAS"
    TRISA = %10000000
    TRISB = %00000001
    DEFINE OSC 20
    DEFINE SHIFT_PAUSEUS 3
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 4
    DATAIN VAR BIT[16]
    ' ----- PORTB.0 = Q7 ----- PORTB.1 = CP ----- PORTB.2 = PL -----
    PAUSE 500
    LOW PORTB.2 : PAUSE 3
    HIGH PORTB.2 : PAUSE 3
    SHIFTIN PORTB.0,PORTB.1,MSBPRE,[DATAIN\16]
    LCDOUT $FE,1,BIN16 DATAIN
    Note: same results no matter what shift mode I use.
    I've cut out those lines of code to simplify reading on this forum, but I repeat the shift command 4 times using each mode and display 4 lines on the LCD.
    Another note, I am chaining two 74HCT165s, hence 16 bits.
    Ok,
    I changed the data to a BYTE, reduced 16 in the shift and LCD commands down to 8 and my test signal worked.
    I don't see what it did not like about having 16 bits?
    :shrug:
    I added one step to my testing, adding a 2nd BYTE of data in the shift and LCD commands and the test signal works good too.
    So it likes 2 BYTES, but not 16 BITS, I can live with that...
    I think it was Ralph that said in the PIC-TO-PIC thread, "one thing at a time".
    Thank you Ralph and a HUMUNGOUS thank you to Mister E for his patience with a newb like me.
    Un gros bisou mon amour! :LOL:
    It works like a charm now, I can flick my bits like I want to.
    Hehe... sti d'fif
    Great to know everything is working fine now.
    I'm going to write "74HCT166" in this thread, just so that the next guy that searches for that chip can find this thread.
    I started out using the 166, but the 165 is also good for my application. Maybe including the word here can save someone else the headaches I had trying to get the 166 to work.
    Oh yeah, might as well include the other variants:
    74HC166
    74LS166
  1. LCDOUT w/custom interface?
    By Mike, K8LH in forum PBP Extensions
    Last Post: - 3rd March 2015, 04:54
  2. Replies: 33
    Last Post: - 19th March 2010, 04:02
  3. 'SCI' interface
    By ecua64 in forum Off Topic
    Last Post: - 29th September 2005, 17:02
  4. PIC12F629, useing all I/O pins
    By Jcee324 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2004, 12:05
  5. User Configuration Interface in PBP
    By Radiance in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 09:00
