Timer1 usage in PIC18F252
Results 1 to 7 of 7
    EShatara's Avatar
    EShatara Guest
    Default Preload Register on service
    I'm also assuming that I will need to reload the TMR1H/L register as I exit the interrupt service routine. Correct?
    Sep 2005
    Campbell, CA
    Generally no. If you are interrupt driven, and you need an interrupt every 'x' seconds then your ISR would reload the registers with the appropriate values as soon as possible (to insure correct timing). There is no need to reload them upon exit.
    In PBP, I normally run in "pseudo-interrupt" mode. I sit in a tight loop polling PIR1.0 until it goes true, clear that bit, reload TMR1H and TMR1L then enter my main routine. After the routine, I go back to the polling mode.
    I put all my high-priority items (such as checking the serial port interrupt bit) in the tight loop, and all the normal stuff in the main program. I avoid pauses whenever possible and instead rely on the timer to provide timing information.
    Charles Linquist
    EShatara's Avatar
    EShatara Guest
    Default Thanks
    >Generally no. If you are interrupt driven, and you need an interrupt every 'x' >seconds then your ISR would reload the registers with the appropriate >values as soon as possible (to insure correct timing). There is no need to >reload them upon exit.
    That's what I meant...thank you
    >In PBP, I normally run in "pseudo-interrupt" mode. I sit in a tight loop >polling PIR1.0 until it goes true, clear that bit, reload TMR1H and TMR1L >then enter my main routine. After the routine, I go back to the polling >mode.
    I already have a tight loop polling my serial port looking for a charaacter. Are you saying I can use the timer without having it generate an interrupt?
    Hadn't thought about that....That could be quite easy to implement in my code.
    Thanks .... chris
    Sep 2005
    Campbell, CA
    Yes, here is a quick code example:
    FastLoop:
    IF PIR1.0 = 1 THEN
    PIR1.0 = 0
    TMR1H = TimerPreloadValue.Highbyte
    TMR1L = TimerPreloadValue.Lowbyte
    GOSUB MainProgram
    IF PIR1.5 = 1 THEN
    Gosub KeyboardInputRoutine ' HSERIN clears PIR1.5
    GOTO FastLoop
    MainProgram:
    'Do something here every time the timer rolls over
    ' This works perfectly as long as your 'Main Program' never takes as long as the timer period. The code sits in the FastLoop waiting for either a keyboard input or a timer timeout. When the timer timeout occurs, then the MainProgram is executed. If you output data in your MainProgram, that data will be output at a regular interval regarless of the length of your program.
    Just remember - stay away from PAUSEs in your main program whenever possible!
    Charles Linquist
    EShatara's Avatar
    EShatara Guest
    Default Thanks again
    Thanks Charles...you've been most helpful....Chris
  1. Software PWM using Timer1
    By muqasim in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 11:49
  2. Help with TIMER1 + SLEEP
    By Yodoad in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 15:07
  3. Time Period of Timer1
    By arnol34 in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 00:31
  4. Timer1 and Interupt wierdness
    By mind in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2005, 01:24
  5. Use of Timer1 with 16F819
    By Barry Johnson in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 16:25
