BUSY line technique
Results 1 to 9 of 9
Threaded View
  1. #3
    OK,
    How does this process look:
    - all PICs define BUSY LINE pin as INPUT.
    - pull-up resistor on BUSY LINE.
    - to transmit, a PIC checks if BUSY LINE is HIGH (available), BUSY LINE pin set LOW (busy). Pin is automatically set as OUTPUT by PBP LOW command.
    - once finished transmitting, BUSY LINE pin is set HIGH (available), then sets pin as INPUT.
    I figure it's going to be extemely bad luck for a 2nd PIC to see the line as available just when another PIC was in between checking the status of the line and setting it to busy.
    Would a simple solution be adding a short delay and checking the status a 2nd time? Or am I worrying about something that will happen 'most likely' never.
  1. Replies: 0
    Last Post: - 3rd February 2009, 00:23
  2. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  4. Errors In MPLAB 8.02
    By HOTLNC in forum mel PIC BASIC Pro
    Last Post: - 4th June 2008, 14:52
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
