No I dont think you can make an array constant. If you want an array you will have to use a variable like this:
label VAR BYTE[length]
Why not using the internal eeprom instead?Originally Posted by cmolson
Usually that's what i do instead of using Array... well if the PIC have EEPROM and/or free EEPROM storage.Code:ArrayIndex var byte ArrayData var byte ' PreLoad EEPROM at programming time ' =================================== ' data @0,$10,$20,$30,$40,$50 ' ' ' Read data from EEPROM ' ===================== ' Read ArrayIndex,ArrayData
Good luck!
