Debug with parity?
Results 1 to 5 of 5
Threaded View
    cmolson's Avatar
    cmolson Guest
    Default Debug with parity?
    Hello again! I have figured out the problem with the inverting of the bytes which I had before. It was one of those cases where the answer is starring you in the face but you are too tired to see it. Now I think I got myself into somthing too deep. Here is what I need to do:
    Send data serially at 9600bps with odd parity.
    Using a pic 16F84A
    Data must be sent on portb.7
    Oscillator is fixed at 3.579mhz
    Now using debug i am able to send data perfectly and recieve at 9600 baud using 3.579mhz. however the problem comes in when I have to use parity. Is there any way to set parity using debug? I looked throught the manual and found all the other DEFINE's for debug, but there isn't one for parity.
    Update:
    I have tried serout and serout2, both do not function proporly on my pic at 9600baud. Is there a way to speed them up by defining static port and baude?
    I'm thinking of maybe of an assembly routine to transmit the data.... I would just like some ideas to overcome this, not actual code.
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:41
  3. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  4. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  5. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
