interfacing SPI with 2 pins?
Results 1 to 7 of 7
    Apr 2005
    I wish I had access to more pins, but all I readily have access to is GND,5V, and 2 GPIOs. I'm guessing it may just not be possible since I need to connect SI,SO,CS,and SCK to my SPI controller.
    Then you're probably stuck with putting another PIC in there.
    Use something like a PIC16F630, and communicate serialy (2-pins), between the PIC's. Then the '630 can talk to the SPI device, with pins left over for other things if you need them.
    Apr 2005
    That's what I figured...thanks for the input
  1. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 05:08
  2. 16-bit SPI problem
    Last Post: - 19th June 2008, 16:42
  3. SPI Interfacing
    By toofastdave in forum Serial
    Last Post: - 18th November 2007, 12:15
  5. Timed pulses on 2 pins
    By Danie Joubert in forum mel PIC BASIC Pro
    Last Post: - 15th March 2004, 08:38
