PCB Making
Results 1 to 13 of 13
Thread: PCB Making
    Dec 2004
    nebraska
    Default PCB Making
    Hi Everyone
    I was wondering if anyone could give me some ideas on making or having Printed boards made at a reasonable price. I currently use PCBExpress and they do a good job, however they are pretty expencive and you have to order at least two boards. I hope someone could give me an idea of where else to have them made. Or a link that explains how to do it yourself. And not the sharpy marker way.
    Shawn
    eoasap's Avatar
    eoasap Guest
    i use www.pcbfabexpress.com (refer 'eoasap' if you use them please)
    2 layer
    5 board min @ $13/board
    (ends up being $80 shipped to me, 5 day turn time)
    7 mil trace & spacing
    15 mil via's
    unlimited drill sizes
    soldermask, silkscreen included
    www.pcbpool.com is one i was thinking of trying, but i dont like the huge shipping they charge.
    Mar 2005
    Iowa, USA
    Lightbulb
    When I get up to speed with Eagle Cad, I intend to use http://www.batchpcb.com. They are geared towards the hobbyist market.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Perth, Australia
    I make my own using a laser printer, a copy of time magazine, and iron and some etching compound.
    check out this link for detailed destructions:
    http://www.fullnet.com/u/tomg/gooteepc.htm
    This method is very good for prototypes or when you only need 1 or 2 pcbs. It works out MUCH cheaper!
    eoasap's Avatar
    eoasap Guest
    how well does that work? that does seem like a really cheap, fast, and convenient way to make (small) boards from home.
    Perth, Australia
    it works very well... ive used the method to make over a dozen boards and they all turned out perfect... the trick to making sure it works is not to skimp on the iron... make sure the printed page and board get nice and hot.
    Sep 2003
    Vermont
    I use Eagle for the board artwork, and Injectorall to print the board. I had little success with iron on, and my consistency was lousy. The photo process is more difficult, but the the results look professional, board after board.
    Ron
    Perth, Australia
    Strange, cos ive had 100% success with the iron on method.
    Nov 2004
    Saskatchewan Canada
    For the dinky few I make in a year I used the photocopy method as well. I bought "special" paper from Digi-Key at the time to do it. I haven't done enough of them yet for them to look 100% perfect (meaning some of the lines were a bit jagged), but it is cheap to do for making a few prototype boards where looks might not be a big issue.
    I checked out that Kamikaze47 listed and I think my next ones will be better using the tips there.
    Bart
    BertMan's Avatar
    BertMan Guest
    I used Advanced Circuits when I was pumping out 5000 at a time, using my own gerber files. Not sure if they are cheap for small orders though. Also, check out Sparkfun.com. They do small orders of 1 and 2 at a good price.
    Aug 2005
    I too use photoresist boards as they come out accurate.Foils can be very close together.I print the foil layout on a laser printer transparency.Once you have it setup, the whole process of expose,develope,and etch takes about 40 minutes.Drilling time of course depends on the number of holes.One nice thing is the component holes are etched out,letting the drill bit slide right into place.The boards are more expensive and you need the ultraviolet light.For a good looking one time project its perfect.
    Dec 2004
    nebraska
    Thanks alot everyone you have all given me some more options for making PCB's.
  1. Gerber - PCB Layout Software??
    By kevj in forum General
    Last Post: - 3rd April 2013, 07:51
  2. The green stuff on a PCB
    Last Post: - 16th April 2008, 13:48
  3. PCB Layout Service
    By alex1202 in forum Adverts
    Last Post: - 23rd August 2007, 23:50
  4. Replies: 0
    Last Post: - 14th April 2007, 07:17
  5. Large-ish PCB order...others wanted...
    By skimask in forum Off Topic
    Last Post: - 16th June 2006, 03:43
