Microcode Studio Plus Loader?
Results 1 to 14 of 14
    Hi Keith
    1. When you programmed the bootloader into your PIC did you make sure that the MCLR pin was set as MCLR and not an IO pin ?
    How do I do that?
    2. Is your MCLR pulled up with a resistor or have you tied it directly to +5V ?
    With a Resistor.
    3. Is Microcode loader set to "Auto" baud rate or is it fixed at the wrong speed?
    Yes, to Auto
    4 Try the bootloader circuit with 100R instead of 10uF !
    Thx, I will try that.
    When the bootloader is displaying a message saying it is waiting for a reset, connect the MCLR pin to 0V momentarily and it should then reset the PIC and bootload the new program.
    I have connect the MCLR PINT TO 0V, but it still don't work.
    I'm using the Max1672 switching regulator, and it has a soft on pin, so I must press the ON button on my keypad for the power to go through to my PIC.
    I have done this and then momentarily connect MCLR to GND, but still no luck?
    Any idea what else I can try?
  1. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 20:35
  2. Interrupt & device setup for a PIC16F628A in Microcode Studio Plus
    By wildpikachu in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2008, 17:28
  3. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 02:18
  4. Microcode studio and USB pics
    By KPDes in forum mel PIC BASIC Pro
    Last Post: - 27th May 2007, 10:28
  5. How to used ICD of microcode studio
    Last Post: - 19th November 2005, 01:29
