math problems (again)
Results 1 to 2 of 2
    lab310's Avatar
    lab310 Guest
    Default math problems (again)
    I need some way to calculate x^y (power function) where x is a word variable (0-65535) and y is selection of ( 0.5 , 0.6 , ..., 0.9, 1). Is there a some eficient way to do this,meaning not calculating series or some large tables . Integer result with some marginal error would be fine.
    Jul 2005
    Lookup tables or a series solution maybe the easiest way of calculating it.
    You could try an assembler version. Look at this page:
    http://www.piclist.com/techref/microchip/math/index.htm
    Scroll down to the PICList post "x^y routine implementation" section
    Let us know how you get on.
    Paul.
  1. Pulsin Math question
    Last Post: - 2nd April 2008, 17:15
  2. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 11:22
  3. PIC18Fxx math 24 & 32 bit
    By ronsimpson in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2006, 13:52
  4. not quite understanding the MATH function
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 17th January 2006, 21:20
  5. math problems - large numbers
    By Tomasm in forum mel PIC BASIC Pro
    Last Post: - 16th February 2004, 08:48
