Software PWM Problems
Results 1 to 6 of 6
    Default Software PWM Problems
    Hi! want to read the 8 Bit AD of the 12F675 an put it out as PWM with duty cyle between 0-100%.
    My Programm is working well, but when AD gets 5V, I get Pulses out with 400ĩS Pause. But at AD 5 V it should be permanently on, without Pulses
    I donīt know whats the problem.
    Here Is my Programm, I attached the Scope Picture.
    Define OSCCAL_1K 1 ' Calibrate internal oscillator
    ' Define ADCIN parameters
    Define ADC_BITS 8 ' Set number of bits in result
    LED Var GPIO.0 ' LED is bit 0, PIN 7
    adval var word ' Create adval to store result
    i var word
    ANSEL = %00111000 ' Set AN3 analog, rest digital
    CMCON = 7 ' Analog comparators off
    loop:
    ADCIN 3, adval ' Read channel 3 to adval
    i = 256 - adval
    I = i * 10
    Pulsout LED,adval ' Puls is 2,56 ms
    Pauseus i 'cycle = 5,12ms = 195 Hz
    Goto loop ' Do it forever
    Hope, Someone could help me!
    With an A/D input > 0V you will always have a pulseout "period" > 0. Grounding the A/D input should stop the output pulse.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I think you missunderstood something, the 12f675 hasnīt got a Hardware PWM, so I want to emulate it in Software! And my Problem is that I could not put the output permanently on, between 0 an 100% der must be pulses, but on 0% the output should have ground signal (thats working) and on 100% the output should have high signal, and thats the problem, it isnīt a countinously line it should be!
    loop:
    if adval<250 then
       i = 256 - adval
       I = i * 10
           high led
    If you can change your PIC, use the 12F683. It have an internal PWM module.
    Sep 2005
    Campbell, CA
    If you *REALLY* need smooth PWM out of your chip, it is possible.
    One approach would be to set up a hardware timer to give you a constant period (say 100uSec), and then use an interleave-type A/D routine. You could do the conversions (and the math) on consecutive timer rollovers.
    Using this technique you could get 8 bits of resolution and 0 to 100% duty cycle at 40Hz. Not great, but possibly usable.
    Charles Linquist
    (OK, just an idea here - worth a try)
    With the AD result set to 8 bits your result will vary from 0 to 255. Try changing the line:
    i = 256 - adval
    to
    i = 255 - adval
    and see what happends. Even at full scale (adval=255) your i variable will be 10 if you subtract adval from 256. You will probably still get short glitches but hopefully you will end up closer to what you want.
    /Henrik Olsson.
  1. Software PWM
    By muqasim in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 14:21
  2. Software PWM using Timer1
    Last Post: - 18th December 2009, 11:49
  3. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  4. 2 PWM in 16F690 problems
    By ciendavila in forum mel PIC BASIC
    Last Post: - 27th April 2008, 09:03
  5. Variable PWM on 2 Channels using software.
    Last Post: - 23rd September 2006, 01:34
