Having now got that piece of code working it has presented this:
If you remove power to the PIC and then reconnect, it of course first looks for the USB and data as per the Gosub DoUSBin etc. As at this stage the USB databuffers are empty, ie no data being sent, it stores the EEPROM variables as 0, instead of retaining the previously stored numbers.
I have come up with this, what i think, long winded solution.
Where by the top three lines of code read:
And thenCode:Main: Gosub DoUSBIN Gosub CheckData Gosub DoUSBoUT
Obvioulsy in VB when i write the data again, i set BufferOut(10) = 1 to write the new variables.Code:CheckData: If USBBuffer[9] = 0 Then Read 1, SecondsDelayOut ' read previously stored Read 3, MinutesDelayOut ' variables from EEPROM Read 5, HoursDelayOut ' before they are blanked SecondsDelayOut = SecondsDelay MinutesDelayOut = MinutesDelay HoursDelayOut = HoursDelay Return Else SecondsDelay = USBBuffer[11] MinutesDelay = USBBuffer[13] HoursDelay = USBBuffer[15] Write 1, SecondsDelay Write 3, MinutesDelay Write 5, Hoursdelay EndIf Return
Is this the easiest way?
