USB, PIC18F2550 and VB
Results 1 to 5 of 5
    Have you tried something like incrementing a variable in the DoUSBin loop, and exiting once it reaches a certain value?
    DoUSBIn:
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    USBService ' keep connection alive
    X = X + 1
    PAUSEUS 5000 ' 5mS delay
    IF X > ExitVal THEN JumpOut
    USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
    JumpOut:
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    Essex, UK
    Thank you so much Bruce, that has been driving me mad for weeks on end. I've been working alot on the other code and kinda working around this, but it works very well indeed now. You're right, it now exits from the loop and back to the main routine. You're a genius !!
    Cheers again.
    Feb 2005
    Essex, UK
    Having now got that piece of code working it has presented this:
    If you remove power to the PIC and then reconnect, it of course first looks for the USB and data as per the Gosub DoUSBin etc. As at this stage the USB databuffers are empty, ie no data being sent, it stores the EEPROM variables as 0, instead of retaining the previously stored numbers.
    I have come up with this, what i think, long winded solution.
    Where by the top three lines of code read:
            Gosub DoUSBIN
            Gosub CheckData
            Gosub DoUSBoUT
    And then
    CheckData:
        	If USBBuffer[9] = 0 Then
                Read 1, SecondsDelayOut     ' read previously stored
                Read 3, MinutesDelayOut     ' variables from EEPROM
                Read 5, HoursDelayOut       ' before they are blanked
        	        SecondsDelayOut = SecondsDelay
        	        MinutesDelayOut = MinutesDelay
        	        HoursDelayOut = HoursDelay
            Else
    	        SecondsDelay = USBBuffer[11]
    	        MinutesDelay = USBBuffer[13]
    	        HoursDelay = USBBuffer[15]
    	        Write 1, SecondsDelay
    	        Write 3, MinutesDelay
    	        Write 5, Hoursdelay
            EndIf
    Obvioulsy in VB when i write the data again, i set BufferOut(10) = 1 to write the new variables.
    Is this the easiest way?
  1. Sending data over USB via VB
    Last Post: - 12th September 2005, 02:00
