Sendin data from PIC to PIC
Results 1 to 8 of 8
    Mentor, Ohio
    Smile
    Hi Mastero,
    Okay so you take this concept and have your first PIC send the request to the other PIC. I have a project going on where I have 20 PICs gathering alarm information and they simply send the data to a master board that displays the information on a display and then prints it out on a POS printer. I simply use SEROUT2 from the sending boards and monitor a "busy" line that tells the sender the line is clear and the receiver looks for the "busy" line to go low at which time is enters a SERIN2 routine. The receiver keeps the "busy" line low until the end user acknowledges the receipt of the alarm and then the receiver clears the busy line and awaits any new traffic.
    Is this like something you are trying to do? I just thought that why would you have one PIC receive a command from a PC just to retransmit it to another PIC when one could do the whole thing and eliminate the middle man.
    BoBK
    Sep 2005
    Campbell, CA
    Without knowing what you are really trying to accomplish -
    I use SERIN, SEROUT (and SERIN2, SEROUT2) extensively to accomplish PIC-PIC communcation.
    Some things to consider:
    Both PICs should be crystal controlled. The internal 4Mhz oscillators usually aren't accurate enough for reliable communication. There are many ways around this, but if you are a beginner, take the easy approach - use a crystal, oscillator or resonator to insure they are both running at a known frequency.
    I assume that you aren't using a level converter (such as a MAX232) anywhere in the system.
    Use a pull-up or a pull-down resistor on the data line between the two parts.
    Use a pull down if you are sending data inverted (recommended), or a pull-up if you are sending data "true". This will help insure that all bytes - including the first one, are received properly. A 10K resistor will work fine.
    Start out at 2400 baud. If you need faster communication, you can later run at up to 38K baud if both your PICs are running at 20Mhz.
    As a debug aid, you can connect the PICs output directly to a PC if you are running in INVERTED mode. This can be a great help in figuring out what is really going on.
    Charles Linquist
    mastero's Avatar
    mastero Guest
    Thanxs guys will work on it and post later..
    Mastero
    Dec 2003
    Wichita KS
    Take a look at the FAQ,
    I have wrote a section on this very thing...
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    mastero's Avatar
    mastero Guest
    Thanx but i already solved that problem .... the two pics are comunicating fine ... as required ...
    I am using 16f628A the new problem i am facing is the RAM, when i am under 27 every thing is fine but when i cross 30 things go the other way ... what is the max ram to work with for the 16f628.?
    search for RAM came back negative on this forum
    Any help is good
    Thanx
    Mastero
  1. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 22:04
  2. Send data to PC USB
    Last Post: - 18th December 2009, 21:57
  3. PIC to PIC Serial data using Cat5 cable
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2007, 02:42
  4. send serial data to PIC 16f84 ausing VB6
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 21:14
