Need PC software solution
Results 1 to 10 of 10
    Thanks Luciano,
    This seems to be a great solution but still need an external module. At least it's not as expensive as any other scope. Anyways i keep it in mind and on my list.
    @Ralph
    Well i don't really know as now. In fact i know nothing about the signal to be recorded and reproduce. I thought about a sound-card recording but... Of course i can take my scope and use it on the road but i hate to have few ten thousand dollar on a 'on the road job'/ Maybe i'll have no other choice. IMHO SerialComm or Parrallel Port could be fast enough... maybe soundcard too.
    Yeah i assume i should know more about but... my customer don't know much
    Anyways, if you have any solution, i'm all ears.
    Thanks again Luciano and Ralph.
    Back in Canada soon! Maybe next week... in the snow... arrrgh!
    mmmpfff no ! no soundcard after all... assuming the rise/fall time caused by the input capacitor an all the a/d blahblah... not a good solution
    Well one thing i know, is that its to replace a load of old unit based on first generation Z80. The customer already tried to grab the data with hyperterminal and other program on various baud rate, bit mode, parity or not, inverted or not... all of those test failed once they tried to send the same data as grab with these programs.
    It's a home-brew system made in the 80's and the egineer who did it is dead, no traces of it, no code, no schematic, no nothing...
    I guess it's a home made protocol. It's 2 wire communication : ground and signal, no clock, no balanced lines... so 4800 Bauds is certainely the fastest speed.... still a guess once again
    Italy
    Hi Steve,
    See this link. The cables schematics are on the same page.
    (Download 1.36 MB).
    Luciano
    http://www.virtins.com
    Virtins Sound Card Instrument
    You may download it from the link below and evaluate it for 7 days free
    of charge, after which the software will stop running if it is not authorized.
    Feb 2004
    Germany
    Hi Steve,
    here is yet another "SoundCardScope"
    (Dual Channel Storage Oscilloscope)
    it has some nice built in features like
    * dual channel generator for sin, square, triangle and sawtooth waves
    * fourier analysis
    If you are concerned about the input impedance and capacitance of the soundcard, it shouldn't be much of a problem to build some probe with an OpAmp etc.
    regards
    Ralph
    Thanks guys. Those software sounds great to me. I have some software like that too but never played with. Once at home, i'll try the above and come back back with my comments.
    Thanks again!
    Feb 2004
    Germany
    Hi Steve,
    I have read the ELEKTOR Article
    (over here we call it DEFEKTOR) ;-)
    And I have had a look at the different solutions they have "tested"
    I think there are two that spring to eye in the < $500 range
    * Swordfish PS40M10 (for a Pocket sized PnP solution for use in field)
    (Nice and small solution at an acceptable price but limited features)
    * BitScope BS-310U (as a "one for all" solution on your bench)
    (Best value for money, but a bit "bulky" for a mobile solution, however smaller than an standalone scope)
    If you are willing to spend a "bit" more money I can recommend the Fluke 123
    regards
    Ralph
    i already have the Fluke 124(same as 123 but 40MHZ)! NICE MACHINE indeed! BUT if i can skip the idea to have any external unit, just the laptop, this will be interesting.
    It's a real pain to travel, pass the cutoms and all the blah blah at each airport.
    BTW, thanks for all suggestion. I'll be back soon with my comments about the 'software only' solutions.
  1. Gerber - PCB Layout Software??
    By kevj in forum General
    Last Post: - 3rd April 2013, 07:51
  2. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 11:04
  3. Sending menu to PC from PIC16F876A
    By joseph Degorio in forum Serial
    Last Post: - 12th November 2007, 08:03
  4. Replies: 3
    Last Post: - 26th November 2006, 22:47
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
