XPort or Connect Me help???
Results 1 to 11 of 11
    Feb 2004
    Germany
    William,
    to get started quickly you could order one of the "Dongle"-PCBs.
    ($8 isn't too much, is it?)
    another low cost option is to use some short pieces of wire and solder the XPort to a connector (or DIP-Socket) that fits the grid of the breadboard.
    (That makes it easy to reuse the XPort later on the final target PCB.)
    regards
    Ralph
    Sep 2005
    Campbell, CA
    In my application, I had to give the user the ability to change IP addresses, protocols (UDP vs telnet) and a variety of other parameters from a menu without using any third-party software.
    Requiring users to load PORT TOOL and other software just didn't fit with my idea of a professional product, one that I could (and do) sell to customers including the military.
    As it is, everything is menu-driven through the serial-port interface, and is easy to use.
    It should be noted that I use one serial port, and multiplex the TxD and RxD between a MAX232 and the XPORT. It works flawlessly.
    Charles Linquist
  1. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  2. xport code, have example, confused though
    By kenpo in forum mel PIC BASIC Pro
    Last Post: - 30th March 2009, 20:59
  3. Haw to connect two pic?
    By edysan in forum Serial
    Last Post: - 24th August 2007, 08:45
  4. xport + connecting 2 networks
    By rf_xport in forum General
    Last Post: - 12th July 2006, 07:26
  5. Has anyone used the Lantronics Xport
    By octavio bru in forum mel PIC BASIC Pro
    Last Post: - 14th September 2004, 12:51
