XPort or Connect Me help???
Results 1 to 11 of 11
Threaded View
  1. #6
    Feb 2004
    Germany
    Quote Originally Posted by ccsparky
    Once I have set up each XPorts IP and installed Redirector, I assign each XPort to it's own comm port in redirector and it's off to the races. Sounds simple enough. By opening say comm port 4 a connection is made to the XPort that was assigned to that port and so on. Wow
    That's exactly the way it works !
    So at this point the only way I can communicate with the XPort is with a PC that has redirector installed, is this the only way?
    This is definitely not the only way, but it is the easiest way!
    How many comm ports can be created with Redirector?
    The Redirector supports up to 80 ports,
    and you can even have more than one XPort assigned to the same virtual com port.
    regards
    Ralph
  1. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  2. xport code, have example, confused though
    By kenpo in forum mel PIC BASIC Pro
    Last Post: - 30th March 2009, 20:59
  3. Haw to connect two pic?
    By edysan in forum Serial
    Last Post: - 24th August 2007, 08:45
  4. xport + connecting 2 networks
    By rf_xport in forum General
    Last Post: - 12th July 2006, 07:26
  5. Has anyone used the Lantronics Xport
    By octavio bru in forum mel PIC BASIC Pro
    Last Post: - 14th September 2004, 12:51
