RPM counter
Results 1 to 9 of 9
Thread: RPM counter
    Sep 2005
    Dayton, Ohio
    1. What chip are you using?
    2. Read the datasheet. It will have a section on each Timer/Counter available on your particular PIC. It tells you exactly what values to write to each register to set up the timer as a counter and how to read/write the current value of the counter. You will also be able to set up one of the I/O pins as a trigger for the counter and select rising/falling edge for triggering. Read up on the prescaler, you may need to set that up too.
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Im using an 18F252. Im looking through the datasheet and I found that Timer0 uses the T0CON register and on the pin diagram it says that T0CKI is pin 6 (PortA.4). How to the timers work? I've never done anything with them before and I'm not even sure what they do.
  1. Interrupt RPM and Taylors Elapsed time on 18F4620
    Last Post: - 3rd February 2010, 17:12
  2. Pulsin vs. Interrupt RPM measurement
    By Tobias in forum General
    Last Post: - 31st December 2009, 02:29
  3. 16f877A and tmr1 external crystal question
    By comwarrior in forum General
    Last Post: - 13th July 2009, 01:40
  4. RPM - DIV32 Problem
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 11th April 2008, 05:33
  5. Microcontroller with 2 way paging application problem
