Cool, what a great question!! Unfortunately, the answer is no. For a couple of reasons.
First, you forgot the "STR"
Second, the STR portion of the SERIN2 command, grabs the number of bytes to receive at the start of execution, and doesn't check to see if it's changed later on.
If you look at the .ASM file generated for this line it looks something like this... (comments added by me)However, I think this might work.Code:; SERIN2~1.BAS 00018 serin2 Rx,16780,[WAIT("!"),str BytesIn\BytesIn[0]\"~"] SERIN2DPIN?T _Rx // PIN to use _Rx SERIN2MODE?C 0418Ch // Mode 16780 LABEL?L L00001 SERIN2WAIT?CL 021h, L00001 // wait for "!" SERIN2COUNT?B _BytesIn // Number of bytes to receive SERIN2CHAR?C 07Eh // terminating character SERIN2STRC?B _BytesIn // Get the String
SERIN2 Rx,16780,[WAIT("!"),BytesIn[0], STR BytesIn[1]\BytesIn[0]\"~"]
Code:; SERIN2~1.BAS 00020 serin2 Rx,16780,[WAIT("!"),BytesIn[0], str BytesIn[1]\BytesIn[0]\"~"] SERIN2DPIN?T _Rx // PIN to use _Rx SERIN2MODE?C 0418Ch // Mode 16780 LABEL?L L00002 SERIN2WAIT?CL 021h, L00002 // wait for "!" SERIN2?B _BytesIn // get number of bytes in packet SERIN2COUNT?B _BytesIn // STR byte count SERIN2CHAR?C 07Eh // terminating character SERIN2STRC?B _BytesIn + 00001h // Get the STR
