input command (newbie question)
Results 1 to 3 of 3
    kctan's Avatar
    kctan Guest
    Default input command (newbie question)
    i am new and i write the input code in microcode studio plus like this
    i using PIC16F877A
    define osc 20
    trisa = %111111
    trisb = %00000000
    x var byte
    start:
    if porta.0 = 1 then
    portb.0 = 1
    portb = %00000000
    when i simulate in proteus 6, i got nothing at output LED
    when i was pressed a switch in proteus, it got signal go in and the voltage is 5.33 after when at open switch i find that porta.0 pin still got voltage that is 3.44 wat is the problem
    wat's wrong with my coding?
    define osc 20
    trisa = %111111
    trisb = %00000000
    x var byte
    start:
    x=0
    while porta.0 =1 and x = 10
    portb.0 = 1
    x=x+1
    wend
    with this code i'am also cannot work so wat is my problem in input?
    does my program write wrong?
    Hi kctan,
    Nothing wrong with the first example. Except there's no GOTO at the end to form a loop. (but you probably just missed it with the cut&paste) You might want to try it on a real chip, instead of a simulator.
    However, in the second example.
    x=0
        portb.0 = 1
        x=x+1
    wend
    The "while" will never execute, because x = 10 will never be True.
    Also, the code shown would be for PicBasic Pro, Plain PicBasic doesn't have a "while" command.
    kctan's Avatar
    kctan Guest
    Talking thanks you
    thanks you
  1. Question from New member A/D input 16f876
    By mbruno in forum General
    Last Post: - 26th January 2008, 15:52
  2. Remote PIC input question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st September 2007, 16:44
  3. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  4. PIC16F628A input question
    By yankee in forum mel PIC BASIC Pro
    Last Post: - 5th January 2006, 04:35
  5. ER Clock input question
    Last Post: - 6th May 2004, 11:10
