Using Microcode Bootloader + CDLite + Hyperterminal
Results 1 to 12 of 12
    May 2005
    Dear milestag
    Yes commucate is OK after i edit asm file by change micro from 16f877 to 16f877a and see below
    radix DEC
    LIST P=16F877a, F=INHX8M
    xtal EQU 20000000
    baud EQU 115200
    __CONFIG _XT_OSC & _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _LVP_OFF & _DEBUG_OFF
    Sep 2005
    Dayton, Ohio
    I don't know what the problem is, maybe someone else here has seen it. If the error is from the bootloader, then maybe you will have to try contacting the author.
    Does your code work okay with a traditional PIC programmer (EPIC, etc)?
    Have you tried compiling for different baud rates or oscillator freq? Double check everything too. Make sure you had the right chip selected in MCS, etc. This is the hazard of freeware....limited or no support (you get what you pay for, right?)
    BTW - Probably unrelated, but I always try everything I can think of....if you are using 20MHz crystal, then I believe you need to use HS_OSC instead of XT_OSC. Someone else here pointed that out to me on an earlier problem I had.
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    May 2005
    Dear milestag
    thank you for advise..
  1. Bootloader files for MicroCode Studio Plus
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 30th December 2007, 18:54
  2. MAX232 Pin Voltages / Bootloader / Microcode Studio
    By rossfree in forum Schematics
    Last Post: - 3rd May 2007, 15:00
  3. CDlite to MicroCode Studio
    By grounded in forum mel PIC BASIC Pro
    Last Post: - 30th January 2007, 15:46
  4. Microcode Bootloader without MAX232
    By kblim in forum Schematics
    Last Post: - 9th August 2006, 02:17
  5. Replies: 1
    Last Post: - 16th June 2005, 02:56
