Using Microcode Bootloader + CDLite + Hyperterminal
Results 1 to 12 of 12
    tdavis80's Avatar
    tdavis80 Guest
    Talking
    MCS is NOT free if used by an educational institution. I think that is what he is complaining about.
    Luckily, any editor will work and there are lots of free boot loaders out there.
    I would recommend checking some of the free programmer's editors because they allow you to enter keywords into a config file. If you use a picbasic config file, it would highlite the commands much in the same way as mcs.
    I use the following boot loader. I like the fact that it doesn't lock the serial port. I can leave it on screen and it only opens the comport when downloading. I have another program that uses the comport while my PIC is running. This means I can have both onscreen and set to the same comport.
    http://www.ehl.cz/pic/pic_e.htm
    I do not have the mclr hooked up. Only the rs232 rx/tx. When I click on the [write] button to send the firmware, I push the reset button on my PIC board. The boot loader then auto-kicks into action and the program downloads in just a few seconds.
    May 2005
    Milestag, sir
    I Just add this line but not work
    DEFINE LOADER_USED 1
    pic 16f877a complier with microcode studio plus 2.2.10
    After download with "Tinybldwin191 into microcontroler "WARNING: PCLATH not initialised before GOTO! ... could not repair.,
    How to fixed it
    here is my code:
    define loader_used 1
    Define OSC 20
    TRISB = 0 'rb0 =output
    TRISB.1 = 0
    Include "modedefs.bas"
    loop: Serout PORTC.6,T9600,["Hello",10,13] ' Display "Hello", next line
    pause 500 ' Wait .5 second
    high portb.1
    Serout PORTC.6,T9600,["World",10,13,10,13] ' Display "World", skip a line
    paUSE 500 ' Wait .5 second
    low portb.1
    Goto loop ' Do it forever
    Sep 2005
    Dayton, Ohio
    What bootloader file did you program into the PIC? I assume you had to edit the 16F876A file?
    Does the bootloader interface identify the connected PIC okay when you click on Check PIC?
    So many variables here, and I don't have extensive experience on this bootloader. I can only tell you what worked for me. Be sure to read all the instructions included with the program.
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    May 2005
    Dear milestag
    Yes commucate is OK after i edit asm file by change micro from 16f877 to 16f877a and see below
    radix DEC
    LIST P=16F877a, F=INHX8M
    xtal EQU 20000000
    baud EQU 115200
    __CONFIG _XT_OSC & _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _LVP_OFF & _DEBUG_OFF
    Sep 2005
    Dayton, Ohio
    I don't know what the problem is, maybe someone else here has seen it. If the error is from the bootloader, then maybe you will have to try contacting the author.
    Does your code work okay with a traditional PIC programmer (EPIC, etc)?
    Have you tried compiling for different baud rates or oscillator freq? Double check everything too. Make sure you had the right chip selected in MCS, etc. This is the hazard of freeware....limited or no support (you get what you pay for, right?)
    BTW - Probably unrelated, but I always try everything I can think of....if you are using 20MHz crystal, then I believe you need to use HS_OSC instead of XT_OSC. Someone else here pointed that out to me on an earlier problem I had.
    Jim Robertson
    Dayton, Ohio
    May 2005
    Dear milestag
    thank you for advise..
  1. Bootloader files for MicroCode Studio Plus
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 30th December 2007, 18:54
  2. MAX232 Pin Voltages / Bootloader / Microcode Studio
    By rossfree in forum Schematics
    Last Post: - 3rd May 2007, 15:00
  3. CDlite to MicroCode Studio
    By grounded in forum mel PIC BASIC Pro
    Last Post: - 30th January 2007, 15:46
  4. Microcode Bootloader without MAX232
    By kblim in forum Schematics
    Last Post: - 9th August 2006, 02:17
  5. Replies: 1
    Last Post: - 16th June 2005, 02:56
