PulsIn question.
Results 1 to 5 of 5
    Peter Oors's Avatar
    Peter Oors Guest
    Talking PulsIn question.
    Can somebody give me an answer?
    How many µs does the PulsIn command take?
    I would like to measure a pulsetrain with 2 kind of pulses,
    91µs high and 13µs low (long), 13µs high and 91µs low (short).
    I use the 16F819 and the 16F628 with 20MHz X-tal.
    I would also like to know how long the pulsin command overhead itself takes with a given frequency.
    For example assume that the pulsin returned 1000 with a 20Mhz crystal would be 2000 microseconds. If It started measuring just after a change in state it would have taken say 1999 + 2000 or 3999 microseconds. Now add the overhead of the command itself and that would be the total time that the command takes.
    Peter Oors's Avatar
    Peter Oors Guest
    Unhappy
    Today I measured a time from the end of a pulse to the end of the PulsIn command of about 12us.
    For me the PulsIn command is useless.
    In assembler it's the best way, but I don't know how to do this in assembler.
    Even in PBP you'll be able to do it with a decent result. Just use the internal timer. The following example is more than enough to start.
        '    Pulse High and Low Timer
        '    File name  : PulseHighLowTimer.bas
        '    Company    : Mister E
        '    Programmer : Steve Monfette
        '    Date       : 13/01/2006
        '    Device     : PIC16F88
        '        This program measure and send to PC, the value of incomming pulses.
        '    The program will send measure of High pulse and Low Pulse length in uSec.
        '    Hardware configuration
             DEFINE OSC 20
             DEFINE LOADER_USED 1
             TRISB = %00000100      ' RB2 as input => Serial RX
             TRISA = 255            ' PORTA As input
             CMCON = 7              ' Disable analog comparator
             ANSEL = 0              ' Disable all A/d
             T1CON = 0              ' TIMER1:
                                    '        Clock Internal
                                    '        Pre-scaller 1:1
        '    Hardware connection
             SignalInput       var PORTA.2
        '    Serial Communication definition
             DEFINE HSER_RCSTA 90h
             DEFINE HSER_TXSTA 24h
             DEFINE HSER_SPBRG 129 ' 9600 Bauds
             DEFINE HSER_CLROERR 1
        '    Alias Definition definition
             T1ON              var T1CON.0
        '    Variables definition
             PulseHigh          var word
             PulseLow           var word
        '    Software/Hardware initialisation
             CLEAR
             GOSUB ClearTimer
        '                             Program Start Here
    Start:
        '    Waiting for falling edge
             WHILE SIGNALINPUT=0 : WEND
             WHILE SIGNALINPUT=1 : WEND
        '    Measure low pulse
             T1ON=1                     ' start Timer
             WHILE SIGNALINPUT=0 : WEND ' wait for next rising edge
             T1ON=0                     ' stop timer
             PULSElow.HIGHBYTE=TMR1H    ' store results
             PULSElow.LOWBYTE=TMR1L     '
             pulselow=pulselow / 5      ' 1 tick = 0.2 Usec @ 20MHZ
                                        ' Divide by 5 to have 1 uSec
                                        ' Resolution
             gosub Cleartimer           ' reset Timer1 register (TMR1L, TMR1H)
        '    Waiting for rising edge
             while Signalinput=1 : Wend
             while signalinput=0 : wend
        '    Measure high pulse
             T1ON=1                     ' Start timer
             WHILE SIGNALINPUT=1 : WEND ' wait for next falling edge
             T1ON=0                     ' Stop Timer
             PULSEhigh.HIGHBYTE=TMR1H   ' Store result
             PULSEhigh.LOWBYTE=TMR1L    '
             pulsehigh=pulsehigh / 5    ' match results to 1 uSec resolution
        '    Send results to PC via RS-232
             hserout ["PulseLow =",dec pulselow, " uSec",13,10,_
                      "PulseHigh=",dec pulsehigh," uSec",13,10,_
                      rep "*"\50,13,10]
             goto start
    ClearTimer:
        TMR1L=0
        TMR1H=0
    I agree, you can have a bit more accuracy in pure assembler... but test with the above first.
    It's only one way to do it... that's the results of a 10 minutes coding... on friday 13
    Peter Oors's Avatar
    Peter Oors Guest
    Red face
    Thanks very much mister_e, you are a great help.
    The text was very helpfull. The accuracy is perfect for me.
    When I measured more pulses, there was a problem.
    Something goes wrong.
    Dividing by 5 gives problems.
    While SIGNALINPUT=0 : Wend ' wait for next rising edge
    T1ON=0 ' stop timer
    The above part I changed in (not the most beautiful way):
    Start:
    GoSub meten
    PULSEhigh1.HIGHBYTE=TMR1H ' Store result
    PULSEhigh1.LOWBYTE=TMR1L
    GoSub meten
    PULSEhigh2.HIGHBYTE=TMR1H ' Store result
    PULSEhigh2.LOWBYTE=TMR1L
    GoSub meten
    PULSEhigh3.HIGHBYTE=TMR1H ' Store result
    PULSEhigh3.LOWBYTE=TMR1L
    GoSub meten
    PULSEhigh4.HIGHBYTE=TMR1H ' Store result
    PULSEhigh4.LOWBYTE=TMR1L
    GoSub Cleartimer
    GoSub meten
    PULSEhigh5.HIGHBYTE=TMR1H ' Store result
    PULSEhigh5.LOWBYTE=TMR1L
    GoSub meten
    PULSEhigh6.HIGHBYTE=TMR1H ' Store result
    PULSEhigh6.LOWBYTE=TMR1L
    GoSub meten
    PULSEhigh7.HIGHBYTE=TMR1H ' Store result
    PULSEhigh7.LOWBYTE=TMR1L
    GoSub meten
    PULSEhigh8.HIGHBYTE=TMR1H ' Store result
    PULSEhigh8.LOWBYTE=TMR1L
    GoSub meten
    PULSEhigh9.HIGHBYTE=TMR1H ' Store result
    PULSEhigh9.LOWBYTE=TMR1L
    GoSub meten
    PULSEhigh10.HIGHBYTE=TMR1H ' Store result
    PULSEhigh10.LOWBYTE=TMR1L
    GoSub Cleartimer
    Pulsehigh1=pulsehigh1 / 5
    Pulsehigh2=pulsehigh2 / 5
    Pulsehigh3=pulsehigh3 / 5
    Pulsehigh4=pulsehigh4 / 5
    Pulsehigh5=pulsehigh5 / 5
    Pulsehigh6=pulsehigh6 / 5
    Pulsehigh7=pulsehigh7 / 5
    Pulsehigh8=pulsehigh8 / 5
    Pulsehigh9=pulsehigh9 / 5
    Pulsehigh10=pulsehigh10 / 5
    Write 1, pulsehigh1
    Write 2 ,Pulsehigh2
    Write 3 ,Pulsehigh3
    Write 4 ,Pulsehigh4
    Write 5 ,Pulsehigh5
    Write 6 ,Pulsehigh6
    Write 7 ,Pulsehigh7
    Write 8 ,Pulsehigh8
    Write 9 ,Pulsehigh9
    Write 10 ,Pulsehigh10
    Stop
    meten:
    GoSub Cleartimer
    While signalinput=0 : Wend ' Waiting for rising edge
    T1ON=1 ' Start timer, measure High pulse
    While SIGNALINPUT=1 : Wend ' Wait for next falling edge
    T1ON=0 ' Stop Timer
    Cleartimer:
    TMR1L=0
    TMR1H=0
    It works fine, not beautiful, I know.
    Thanks for the help.
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 10:17
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 08:02
  4. Pulsin Math question
    Last Post: - 2nd April 2008, 16:15
  5. pulsin question
    By schu4647 in forum mel PIC BASIC Pro
    Last Post: - 29th May 2006, 20:46
