18F2525 Stack Pointer
Results 1 to 3 of 3
    Sep 2005
    Dayton, Ohio
    Default 18F2525 Stack Pointer
    Okay, I found a bug in my code caused by (me) calling subroutines (GoSub) and then using a "GoTo" within that subroutine rather than always using the Return. After a certain number of calls to that subroutine, everything went haywire.
    Lucky I remembered seeing a post on earlier this forum about NOT doing that with 18FXXX, and was able to find the problem and fix it. ....after a tedious adventure in creating a hand-drawn flowchart to map my code and find the missing Returns.
    My QUESTION is.....could I simply insert a "STKPTR = 0" in order to reset the stack and compensate for a few "illegal" GoTos? I would place this at the TOP of my code allowing me to immediately jump back to the "MainLoop" of the program without having to Return from the current subroutine.
    This would still be useful in the interest of speed, to not have to back out of a number nested subroutines. I know it's unorthodox...but will it work?
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    Australia
    You may insert @POP before goto. Do not force "STKPTR = 0" and let PIC control STKPTR. Please let me know whether @POP can fix the problem.
    Yuantu Huang
    Sep 2005
    Dayton, Ohio
    Okay, that makes sense. I am still learning some of the 18FXXX's unique instructions.
    Right now the program runs perfectly (since I fixed those Returns). My question was more for some future ideas.
    Thanks!!
    -Jim
    Jim Robertson
    Dayton, Ohio
  1. PBP method to POP or PUSH to 18F2525 stack?
    Last Post: - 26th September 2009, 21:09
  2. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 11:04
  3. Why is my PIC18F452 reseting?
    By Vincent in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 00:35
  4. Stack Under flow
    By Wayne in forum mel PIC BASIC Pro
    Last Post: - 14th September 2005, 14:22
  5. 48 level Software Stack
    Last Post: - 30th November 2003, 02:07
