button problems
Results 1 to 4 of 4
Thread: button problems
    Unhappy button problems
    hello, i wrote a program for pic16F876 to do the following:
    press button RB7 and led RB1 wil go on and stay on no matter how long you push RB7.
    if you release RB7 the led RB1 will stay on,
    if you push the RB7 again, the led will go off again , no matter how long you push RB7
    This works perfectly standalone, but when i put it in a SUB and call it from the main, it doesn't work properly anymore,
    So push RB7 gosub flipflop, push RB6 gosub onoff (turn led B0 on).
    I used pulldown resistors, so that ain't the problem
    I'm puzzled:
    here is the working program:
    trisb=%11110000
    yy var byte
    yy=2
    portb=0
    start:
    if yy=2 and portb.7=0 then
    yy=10
    if yy=10 and portb.7=1 then
    yy=20
    portb.1=1
    if yy=20 and portb.7=0 then
    yy=30
    if yy=30 and portb.7=1 then
    yy=40
    portb.1=0
    if yy=40 and porta.7=0 then
    yy=2
    goto start
    and now the subroutine version (Can't get it to work!!)
    trisb=%11110000
    yy var byte
    yy=2
    portb=0
    start:
    if portb.7=1 then
    gosub flipflop
    if portb.6=1 then
    gosub onoff
    portb.0=0
    goto start
    flipflop:
    yy=10
    yy=20
    portb.1=1
    yy=30
    yy=40
    portb.1=0
    yy=2
    goto start
    onoff:
    portb.0=1
    goto start
    Who can help me out here ???
    greetz, Maus
    Perth, Australia
    I dont understand what all this stuff with yy is for.
    Why not use something like this:
    if portb.7=1 then                      ' If button is pressed:
        toggle portb.1                     ' Toggle the LED
        loop: if portb.7=1 then goto loop  ' Wait until the button is released
    Perth, Australia
    anyway, the reason for your subroutine not working is becuase this statement will never be true: "if yy=2 and portb.7=0 then", becuase you only jump to the subroutine when portb.7=1.
    Instead of this:
    if portb.7=1 then
    gosub flipflop
    Try just this: "gosub flipflop"
    Also, there is no return from the subroutine... instead of "goto start", put "return"
    simple and short
    thanx, works like a charm
    greetz, Maus
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 17:44
