Read Modify Write problem?
Results 1 to 5 of 5
    Jun 2005
    Thanks Darrel,
    Is this what you meant?
    Variable X0 is the segment pattern and is sent to the output ports.
    TRISB. I use OR to maintain portB.1 as input
    TRISA. I use OR to maintain PortA.2 and PortA.3 as inputs
    Is there an better approach?
    'initialize ports
    TRISA = %00001100 'configure port A outputs = 0
    TRISB = %00000010 'configure port B outputs = 0
    Mark
    'write segments to ports A and B
    PORTB.0 = X0.0 ' Send segments to LED 0 = ON
    PORTA.4 = X0.1
    PORTA.6 = X0.2
    PORTB.3 = X0.3
    PORTB.4 = X0.4
    PORTB.5 = X0.5
    PORTB.6 = X0.6
    PORTB.7 = X0.7
    TRISB = X0 OR %00000010 ' OFF segments = 1 (set to inputs)
    X1=X0 AND %01010000 ' isolate X1= PortA.4 and PortA.6 bits
    TRISA = X1 OR %00001100 'maintain PortA.2 and PortA.3 inputs
    uh, nope.
    I was thinking something more like this.
    PORTA = 0
    PORTB = 0
    TRISB.0 = X0.0 ' Send segments to LED 0 = ON
    TRISA.4 = X0.1
    TRISA.6 = X0.2
    TRISB.3 = X0.3
    TRISB.4 = X0.4
    TRISB.5 = X0.5
    TRISB.6 = X0.6
    TRISB.7 = X0.7
    Jun 2005
    Wink
    Thanks Darrel,
    That is much cleaner! I will give it a try.
    Mark
  1. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  2. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 13:06
  3. Read Write Problem
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 15th June 2009, 19:03
  4. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  5. problem to read write 24LC512
    By edysan in forum mel PIC BASIC Pro
    Last Post: - 19th February 2008, 21:46
