Masking address bits
Results 1 to 13 of 13
    Dave, are you serious? You can't use a variable for that field?
    I'm up the creek also then, my project relies heavily on MCP23016 ICs and controlling them within a loop. One easy alternative would be a bunch of IFs:
    IF loop = 0 THEN I2cWRITE blah,blah2,Constant0,[SteakBledindePatate]
    IF loop = 1 THEN I2cWRITE blah,blah2,Constant1,[SteakBledindePatate]
    IF loop = 2 THEN I2cWRITE blah,blah2,Constant2,[SteakBledindePatate]
    IF loop = 3 THEN I2cWRITE blah,blah2,Constant3,[SteakBledindePatate]
    IF loop = 4 THEN I2cWRITE blah,blah2,Constant4,[SteakBledindePatate]
    IF loop = 5 THEN I2cWRITE blah,blah2,Constant5,[SteakBledindePatate]
    IF loop = 6 THEN I2cWRITE blah,blah2,Constant6,[SteakBledindePatate]
    IF loop = 7 THEN I2cWRITE blah,blah2,Constant7,[SteakBledindePatate]
    But I'm not very keen on this idea.
    Demon, This is the code I assumed would work:
    UNIT0 CON %01110000 'U5's CONTROL BYTE (PCF8574A) I/O EXPANDER
    R_WI2CSW:'READ DIGITAL INPUTS FROM or WRITE DIGITAL OUTPUTS TO PCF8574'S
    SWCNTR = 0
    WHILE SWCNTR < 6
    CONTROL = UNIT0 | (SWCNTR << 1)
    IF READ_WRITE = 0 THEN 'READ INPUT STATUS FROM PCF8574'S
    I2CREAD SDA,SCL,CONTROL,[SWITCHES(SWCNTR)]
    ELSE 'WRITE OUTPUT STATE TO PCF8574'S
    I2CWRITE SDA,SCL,CONTROL,[OUTPUTS(SWCNTR)]
    SWCNTR = SWCNTR + 1
    WEND
    But it didn't work as explained in my earlyer post. This is what I had to do instead:
    UNIT1 CON %01110010 'U6's CONTROL BYTE (PCF8574A) I/O EXPANDER
    UNIT2 CON %01110100 'U7's CONTROL BYTE (PCF8574A) I/O EXPANDER
    UNIT3 CON %01110110 'U11's CONTROL BYTE (PCF8574A) I/O EXPANDER
    UNIT4 CON %01111000 'U12's CONTROL BYTE (PCF8574A) I/O EXPANDER
    UNIT5 CON %01111010 'U13's CONTROL BYTE (PCF8574A) I/O EXPANDER
    R_WI2CS:'READ DIGITAL INPUTS FROM or WRITE DIGITAL OUTPUTS TO PCF8574'S
    I2CREAD SDA,SCL,UNIT0,[SWITCHES(0)]
    I2CREAD SDA,SCL,UNIT1,[SWITCHES(1)]
    I2CREAD SDA,SCL,UNIT2,[SWITCHES(2)]
    I2CREAD SDA,SCL,UNIT3,[SWITCHES(3)]
    I2CREAD SDA,SCL,UNIT4,[SWITCHES(4)]
    I2CREAD SDA,SCL,UNIT5,[SWITCHES(5)]
    I2CWRITE SDA,SCL,UNIT0,[OUTPUTS(0)]
    I2CWRITE SDA,SCL,UNIT1,[OUTPUTS(1)]
    I2CWRITE SDA,SCL,UNIT2,[OUTPUTS(2)]
    I2CWRITE SDA,SCL,UNIT3,[OUTPUTS(3)]
    I2CWRITE SDA,SCL,UNIT4,[OUTPUTS(4)]
    I2CWRITE SDA,SCL,UNIT5,[OUTPUTS(5)]
    Now very elegant......
    I'll have an eye on this once back in town. Interesting...
    Is the same thing happen with Lookup too?
    WichIOExpander var byte
    For Loop = 0 to 6
        Lookup WichIOExpander,[%11110000,%11110001,%11110010,%11110011,_
                               %11110100,%11110101,%11110110]
        I2cWRITE blah,blah2,WichIOExpander,[SteakBledindePatate]
        pause 5
        next
    About now? Just curious
    Steve, I'm not set up to test right now.
    Dave, are you sure you used a BYTE?
    I reread the manual and there is nothing for I2CREAD that says CONTROL byte must be a constant.
    Dave, here's my complete code using a 16F877 and MCP23016:
    ADCON1 = 7 ' A/D off, all digital
    @ DEVICE PIC16F877, HS_OSC, WDT_OFF, PWRT_ON, BOD_ON, LVP_OFF, CPD_OFF, WRT_OFF, DEBUG_OFF, PROTECT_OFF
    define OSC 20
    DEFINE I2C_SLOW 1 ' Access I2C device above 8MHz
    DEFINE I2C_HOLD 1 ' Permit I2C device to hold clock line low
    I2CSCL VAR PortC.3
    I2CSDA VAR PortC.4
    I2CCTRL con %01000000
    I2CLOCB VAR BYTE
    I2CWORD VAR WORD
    I2CLOCB = $06 ' Set location to IODIR register
    I2CWORD = %0000000000000000
    i2cWRITE I2CSDA,I2CSCL,I2CCTRL,I2CLOCB,[I2CWORD]
    PAUSE 12
    I2CLOCB = $00 ' Set location to GPIO register
    I2CWORD = %1111111111111111
    It doesn't work, and it is using a constant.
    I don't understand why either, I had this circuit working a few weeks ago. I'm sure I have something screwed in the code, but I don't see what it can be.
    Just a bit more on the code above, the 1st I2CWRITE sets the pins as output, the 2nd turns them all ON.
    Last Post: - 14th June 2016, 08:55
  2. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  3. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 17:34
  4. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
  5. 18f452 internal eprom help
    Last Post: - 13th July 2004, 16:50
