RGB LED driver, Any comments?
Results 1 to 32 of 32
    Feb 2003
    Quote Originally Posted by paxmowa
    Dude! You're so right.
    Apart from when I am wrong!!!
    PORT D
    PNP collector to +5V feeding emitter to common Anode
    Take the base to 0V via resistor to turn on an LED
    Should read
    PORT D
    PNP *EMITTER* to +5V feeding *COLLECTOR* to common Anode
    That'll teach me to reply in a hurry before dashing out to collect the kids from school
    DOH !!!!
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Thanks for the efford Keith.
    After a bit of sleep and with a cleared head I made up this:
    Updated:
    Swapped PNP and NPN transistors around, replaced BC547 by BD139.
    It aint finished yet i guess.
    I checked the specs for the RGB leds and green and blue chips are rated 3.5 to 3.8 volts, red chip is GaAlAs rated at 1.85 to 2.2 volts. The 3.3 volts from the voltage regulator is to high for the red chip and to low for the blue and green. Will prolly go to 5V supply and put resistors in series with each chip.
    Anyways, thanks again for the help so far,
    UPDATE:
    This is the third version, added resistors in series with each led chip, this should be almost complete i think. Now only add the PIC16F777 and power supply.
    hmmm, I figure there's also the voltage drop over the transistors. about 0.6 volt each.
    So the resistors for blue and green should be 10 ohm and for the red should be something like 82 ohm.
    Getting there... slowly, but getting there none the less.
    Steven
    Sep 2003
    INDIA
    Default RGB LED Drv via RS232
    Hello PAX / Other,
    I am trying a very similar project in which I send a byte (actually 3 bytes for R-G-B) information for each of the color LED via the RS232 Port to form a Colour Combination.
    I am plannig to go about using 3 12F629 for each of the LED's. I am having some problem of communicating the PIC's with the RS232.
    Can anyone share some code samples for the RGB LED out here ?
    regards
    Feb 2005
    Im using a single 12F683 (or 12F675) for controlling the RGB channels and I still have space for an extra potentiometer (for sweep speed) and 2 buttons.
    For PWMing I use PWM instead HPWM, of course if you have 3 HPWM is a little easier, but not much...
    you share a common ground and use a 7805 regulator for the pic, then you can power the regulator and the leds with any value from 5-24V (+ after the resistors)
    I drive luxeon leds without problem
    Have fun
    Jan 2006
    Hey Peu, I'm working on pretty much the same thing with a 12F675 PWMing to 3 Mosfets. Everything is working well except I'm finding when I PWM from GP2 and GP4 the MOSFETs don't really pulse they pretty much just stay on, or switch off when the cycle gets low enough. I'm not sure why, I've poked the ANSEL and CMCON, but it seems maybe the output voltage on those pins is a little different or something. Anyone have any ideas what might be going on? I see you are driving your green channel with GP2, does that work fine for you?
    Feb 2005
    Quote Originally Posted by ERIK
    I used this header in a previous version that used gpio.0 as an adc input and 1,2 and 4 as the pwm channels
    @ device pic12F683, intrc_osc_noclkout, wdt_on, mclr_off, protect_off
    @ device INTRC_OSC_NOCLKOUT
    trisio =%00000001
    ansel =%00000001 'analog off except gpio.0
    cmcon0 =%00000111 'Comparators Off
    pasos con 16
    ciclos con 10
    conta var byte
    puerto var byte
    and this is the routine I use for the led brightness increase:
    for conta=0 to 255 step pasos 'Rise routine
    pwm puerto, conta, ciclos ; puerto is the port to be used
    next conta
    high puerto ; after it reached the top brightness, set port high
    you can use the same routine for decreasing, just change the for next and put a LOW after the loop instead of the high.
    hope it helps
    Pablo
    Mar 2007
    Wink I am a new user.Where is the asm or hex code for this cicuit
    I am a new user.Where is the asm or hex code for this cicuit.
    Thank you very much.
    Quote Originally Posted by eduman View Post
    You haven't written it yet!
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. Scale 8bit ADC RGB LED voltmeter
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2008, 04:37
  5. LCD will not start
