Noritake Display Help
Results 1 to 9 of 9
    Jun 2005
    Default Re:Noritake Display Help
    Thanks for the help. I forgot to mention that this unit is encased and is serial controlled. It only requires 5Volts, Ground and a serial feed. I guess I can assume it uses the opcodes as per the Noritake data sheet and that there would not be anything else on the front end that would require different commands. However, I read that it uses an Epson chipset and not Hitachi. I'll have to compare the commands and see if there are differences. I like the idea about auto incrementating the display intensity however I never really thought that they fade over time. I hope I have not bought a worn out display. I have not received it yet. Oh well, it was fairly cheap. Any further advice around asynchronous serial control would be appreciated. Thanks.
    Feb 2004
    Michigan, USA
    From what I can gather from the Noritake website, your module is both parallel and serial capable. Register and download the datasheet and take a look at the jumper settings. Should be Hitachi compatable even though it uses an Epson chip set.
    I too am using a 4x20 Noritake. Thing works just like any LCD display.
    Sep 2005
    Campbell, CA
    The Noritake datasheets usually have graph of brightness vs. time. You'll see that they get dimmer, but it takes a long time.
    penelopepug, James and Charles are right. If you look at the data sheets for just about any of the Noritake displays they have a test connector on board and can operate on a serial basis as well as parallel. There are solder jumper settings to set the default baudrate and such. I have used the 2x40, 4x20, with the LCDOUT commands and the 128x64 graphical displays for the past 1 1/2 years with no problems. I prefer the parallel interface for the speed but if you can't afford the I/O pins in your design the serial approch works just fine.
    Feb 2004
    Michigan, USA
    OFF TOPIC Dave, care to be a GOD amongst men and share some of that graphics display code?? /OFF TOPIC
    Jun 2005
    Thanks guys. I have downloaded some spec sheets and now I just have to receive the display and start playing with it. This is going to be (hopefully) the beginning of a good experience learning much more about displays. I have been building this high performance arcade helicopter machine for the past few years and am now at the point where I need to build a number of displays. I'm good with hardware but weak on the software side. I need to build display panels (meaning panels with multiple displays) for score, time, level, rating, fuel remaining, ammunition, engine RPMs, lift, chopper integrity, etc.. I know I could use an OSD module and there is one for a VGA monitor or panel available. However I want this to be arcade like with perhaps a combination of display types including Alphanumeric and Numeric LEDs and VFDs. This will surely take me some time to get right. If anyone is interested, I have a website dedicated to the project at http://www.johnnyastro.com/ArcadeChopper/index.htm
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 21:07
  2. Replies: 2
    Last Post: - 14th July 2008, 23:11
  3. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 14:12
  4. need help on display problem
    By sixty9sandals in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 04:57
  5. graphics display
    By adlinsystems in forum mel PIC BASIC Pro
    Last Post: - 12th June 2004, 13:53
