Ascii debug issues?
Results 1 to 12 of 12
    achilles03's Avatar
    achilles03 Guest
    Default Ascii debug issues?
    I had a program that communicated via RS232 to my PC pretty well, but I lost it in a hard drive transfer and can't get a new program to work exactly right.
    The program I have has the following serout2 command repeated in a loop:
    serout2 portb.2,396,["TACOS"]
    On my terminal program, all I get is something like:
    "aeU aeU aeU aeU aeU"
    (the a is actually a Greek alpha)
    I've also tried (with somewhat similar results as above):
    serout2 portb.2,396,[DEC 84,65,67,79,115,33,13]
    I have the terminal program set to recieve at 2400, true, non-inverted, 8-bit and 1 stop bit. What am I missing?
    Thanks in advance for any help!
    what about the osc speed? if different than 4MHZ, did you use the DEFINE OSC ???
    achilles03's Avatar
    achilles03 Guest
    Yeah, I set it to 4Mhz.
    Sep 2005
    Dayton, Ohio
    I am suffering a similar problem here with a PIC18F2525. I know the MAX232 interface is fine, as it works perfect for bootloading. And I can get HSEROUT to work fine, but when I try to use SEROUT I get wierd characters on hyperterminal.
    I am runnig at 8MHz with a ceramic resonator (yes I use DEFINE OSC 8) and using 9600 baud.
    I'm wondering if it's a timing issue with software vs hardware generated serial data. I still need to try generating from other pins. Possible that the USART is still doing something to the TX pin due to the bootloader having configured it. Still troubleshooting ....
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    Are you using TRUE mode with SEROUT?
    Going through the MAX232 you'll need to use TRUE mode. With a direct connection to the PC, you would use inverted.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    In addition to Bruce, what about the config fuses? HS OSC or XT OSC???
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 14:48
  2. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 20:41
  3. Understanding timer issues
    Last Post: - 7th April 2009, 02:56
  4. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 07:51
  5. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 02:46
