Interrupt Problem
Results 1 to 16 of 16
    J_Brittian's Avatar
    J_Brittian Guest
    I'm sorry. I just realized that. Do you reset you're interrupt flag somewhere? Should there be an Intf = 0 just before the retfie?
    Zagreb, Croatia
    Smile
    first off all you forgot to clear int flag
    in your int handler so your PIC will always
    be in interrupt routine. you have to put line
    bcf INTCON,1
    before retfie instruction.
    also I suggest you to turn on and off
    LED in int routine with little delay
    in between (although it is not adviceable to use
    delays in interrupt)
    to see the interrupt more clearly. you can
    use this int handler for example:
    asm
    int_handler
        ; Save Resisters ;
        movwf   wsave               ; Save W Register into wsave
        swapf   STATUS,W            ; Save STATUS Register into ssave
        clrf    STATUS
        movwf   ssave
        movf    PCLATH,W            ; Save PCLATH Register into psave
        movwf   psave
        movf    FSR,W               ; Save FSR Register into fsave
        movwf   fsave
    endasm
        high LED
        low LED
        ; Interrupt Code ;
        ;bsf     _LED                ; Turn on LED
    asm
        ; Restore Resisters ;
        movf    fsave,W             ; Restore FSR Resister
        movwf   FSR
        movf    psave,W             ; Restore PCLATH Resister
        movwf   PCLATH
        swapf   ssave,W             ; Restore STATUS Resister
        movwf   STATUS
        swapf   wsave,F             ; Restore W Resister
        swapf   wsave,W
        bcf INTCON,1
        retfie
    endasm
    Perth, Australia
    I would have thought the interrupt flag would be reset automatically when it returns from the interrupt handler. I havnt seen interrupt routines that reset the flag, but I guess its worth a try.
    Perth, Australia
    Ahh yep, that did the trick. Thanks Ingvar.
    Just a single line at the end of the interrupt handler: bcf _INTF
    Perth, Australia
    Tom: is there any down side of including picbasic commands in your interrupt handler. I thought to work as a proper interrupt it had to be in asm?
    Zagreb, Croatia
    Smile
    You always have to clear interrupt flag in software
    before retfie instruction. If you don't clear the flag,
    instruction retfie will set GIE bit and PIC will be
    interrupted again. Logical AND function beetwen
    int flag bit and int enabled bit (AND-ed with GIE)
    will result in interrupt.
    Zagreb, Croatia
    kamikaze 47:
    well, of course it's better to use asm in my opinion
    but this also work. I try it.
    Kamikaze47 is right.
    There is definately a problem using PAUSE in an ASM interrupt.
    Pause uses 2 internal PBP variables. (R0 and R1). So if, another PBP statement that uses either R0 or R1 gets interrupted, the interrupt routine will change those values and the main program will get confused.
    It's possible to have a pause in the interrupt, IF you save both of the system vars first, then restore them when the int is finished.
    In that case, toms example would look like this...
    R0save VAR WORD
    R1save VAR WORD
    asm
    int_handler
        ; Save Resisters ;
        IF (CODE_SIZE <= 2)
            clrf    STATUS
            movwf   ssave
            movwf   psave
            movwf   fsave
    endasm
        R0save = R0
        R1save = R1
        high LED
        low LED
        R1 = R1save
        R0 = R0save
    asm
        movwf   FSR
        movwf   PCLATH
        movwf   STATUS
        swapf   wsave,W
        bcf INTCON,1
        retfie
    endasm
    But then, like tom says ... "it is not advisable to use delays in interrupt"
    Perth, Australia
    Thanks for that info Darrel.
    Is there a reference somewhere that tells you what (if any) internal variables PBP uses for each command?
    No, unfortunately.
    Depending on how and where certain statements are used in the program, the actual system variables used might change. So there's really no way to make a "List".
    You pretty much have to sift thru the .LST file to find out which vars are used. That includes following every CALL to other routines too. It can take a while.
    PAUSE was easy though, it's pretty small, and only has 1 CALL.
    Of course, you can take the easy route and just save them all to be sure. But then we're back to OXIMBIT's routine again.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 01:34
  3. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 19:02
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 01:17
    Last Post: - 6th March 2005, 01:07
