Although I haven't tried it, the following code should work.
It uses no pauses whatsoever.
' Set up timer1 for /8 prescaler
T1CON = %00110001
TOP:
IF PIR1.0 = 1 THEN
PIR1.0 = 0
TMR1H = $D
TMR1L = $CF
Hcounter = Hcounter + 1
IF Hcounter.0 = 0
GOSUB DOTHEWORK
If Button1 = 0 THEN SecCounter = 60
IF Button2 = 0 THEN BTN2 = 1
IF Button3 = 0 THEN BTN3 = 1
GOTO TOP
DOTHEWORK: ' Gets here exactly once per second
IF BTN2 = 1 AND SecCounter > 0 THEN
LEDFLAG = 1
IF BTN3 = 1 AND BTN2 = 1 AND SecCounter > 0 THEN
HORN = 1
IF LEDFLAG = 1 THEN
TOGGLE LED
IF SecCounter > 0
SecCounter = SecCounter -1
