better way
Results 1 to 9 of 9
Thread: better way
    Sep 2005
    Dayton, Ohio
    I haven't tested it, and it can surely be done more elegantly, but this should be a little closer to what you are attempting....I did not check to see if you are initializing the registers correctly.
    SYMBOL HORN = GPIO.0 'FAULT HORN
    SYMBOL CT = GPIO.2 'CT PIN 5 (TRIPS LOW)
    SYMBOL LED = GPIO.5 'LED PIN 2
    A VAR WORD
    EVENT VAR BYTE
    HORN =0
    LED =0
    EVENT =0
    MONTIOR:
    IF CT = 0 Then FAULT
    GoTo MONTIOR
    FAULT:
    LED = 1
    Pause 5000
    LED = 0
    CHECK:
    For A = 0 TO 60000
    Pause 1
    IF CT = 0
    GOSUB FAULT_AGAIN
    Next A
    EVENT = 0
    GOTO MONITOR
    FAULT_AGAIN:
    EVENT = EVENT + 1
    IF EVENT = 2 THEN THR
    SEC:
    LED = 1
    Pause 5000
    LED = 0
    THR:
    HORN = 1
    Pause 5000
    HORN = 0
    EVENT = 0
    GoTo MONTIOR
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    Sep 2005
    Campbell, CA
    Although I haven't tried it, the following code should work.
    It uses no pauses whatsoever.
    ' Set up timer1 for /8 prescaler
    T1CON = %00110001
    TOP:
    IF PIR1.0 = 1 THEN
    PIR1.0 = 0
    TMR1H = $D
    TMR1L = $CF
    Hcounter = Hcounter + 1
    IF Hcounter.0 = 0
    GOSUB DOTHEWORK
    If Button1 = 0 THEN SecCounter = 60
    IF Button2 = 0 THEN BTN2 = 1
    IF Button3 = 0 THEN BTN3 = 1
    GOTO TOP
    DOTHEWORK: ' Gets here exactly once per second
    IF BTN2 = 1 AND SecCounter > 0 THEN
    LEDFLAG = 1
    IF BTN3 = 1 AND BTN2 = 1 AND SecCounter > 0 THEN
    HORN = 1
    IF LEDFLAG = 1 THEN
    TOGGLE LED
    IF SecCounter > 0
    SecCounter = SecCounter -1
