Is this possible....Newbie question...
Results 1 to 6 of 6
    Italy
    17Cxxx, 18Cxxx, 18Fxxx are not supported by PicBasic because of 16-bit core.
    For those chips you will need PicBasic Pro.
    With PicBasic use a 16F876(A) or a 16F877(A).
    The Analog-to-Digital (A/D) Converter module has five
    inputs for the 28-pin devices (16F876) and eight for the 40/44-pin
    devices. (16F877).
    Best regards,
    Luciano
    CosRush's Avatar
    CosRush Guest
    Thanks for the replies
    So all in all, would it be able to display the figures i want in the way i want it to???
    it will be possible don't worry. Just much code line to type than with PBP. Look the Melabs website, there's few code example for PBC
    http://www.melabs.com/resources/samples.htm#pbc
    There's one that show you how to use LCD wich is the big part of what you need. Luciano suggest you some good PIC model to begin.
    CosRush's Avatar
    CosRush Guest
    Excellent.......
    Thanks very much for the help
  1. Newbie 74hc595 question
    By manjero in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 22:22
  2. newbie with serial com question...
    Last Post: - 16th December 2006, 05:34
  3. Newbie Question - Info Please
    By ehoskins in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 14:50
  4. Greetings from Newbie and a question
    Last Post: - 24th July 2006, 15:52
  5. Newbie question
    By senojlr in forum General
    Last Post: - 11th April 2006, 21:23
