serin DEC
Results 1 to 1 of 1
Thread: serin DEC
    barkerben's Avatar
    barkerben Guest
    Default serin DEC
    I was wondering...
    If I use serin2 and dec, will the read stop when a non numeric character is received?
    For instance, if I have the following arrive at my serial port:
    A12abcd
    and I use the command SERIN2.... [WAIT("A"),dec foo]
    where foo is a byte, will foo end up with the value 12 in it? In other words, is the compiler "smart" enough to notice the following characters are non numeric?
    Also, what would happen if my input string was instead:
    A1234abcd
    1234 is too large to fit into one byte, wich is however what the code is asking for. What kind of error would this give? Would the byte just end up as 255?
    And how about if I had the following:
    Input string is:
    ABCDEFG123
    The command now waits for "A", then tries to read in a numeric value, but the next character is B. Will it keep skipping characters for ever until it finds a numeric value (eventually returning 123), or just return nothing...?
    Cheers,
    Ben
  1. Serin EEPROM Programmer
    By dirtbiker5627 in forum mel PIC BASIC Pro
    Last Post: - 25th February 2010, 00:48
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  3. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
  4. Serin with low voltage
    By f_lez in forum General
    Last Post: - 21st August 2006, 12:52
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 16:54
