WDT-Reset - How to know
Results 1 to 2 of 2
    Hangover, Germany
    Default WDT-Reset - How to know
    Hello,
    we implement the WDT in our code.
    How it is possible to check out, if there was a WDT-Reset ?
    In the init-Part of my code, I check the Bit TO to be cleared and PD to be set (this is the setting after a WDT-Reset), but I think the PicBasic kills them while working on his Reset-Code....
    PIC16F876
    ;Reset ?
    Stat_POR=0:If POR_=0 Then Stat_POR=1:POR_=1
    ;WDT ?
    Stat_WDT=0:IF (TO_=0) AND (PD_=1) Then Stat_WDT=1
    Hangover, Germany
    I've found the solution
    PicBasic insert CLRWDT-commands, before the TO-Bit is checked. But the CLRWDT-command sets the bit !
    So I use some asm on the first lines of the programm to save the STATUS-register.
    @ movf STATUS,w
    @ movwf _dummy
  1. pic reset sometimes
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2008, 17:27
  2. Changing 18F WDT postscaler on-the-fly
    Last Post: - 1st August 2006, 21:09
  3. Software Driven Reset Routine
    Last Post: - 11th April 2005, 00:53
  4. reset and interrupt vectors
    By dtoohey in forum mel PIC BASIC Pro
    Last Post: - 28th February 2005, 22:02
  5. Replies: 5
    Last Post: - 1st December 2004, 12:49
