If only it were that simple Steve. Have tried sending the 10 bit data and still the same results. The data sheet does say that if 16 bits are sent, the first 6 bits are ignore, but thanks for the reply.
Unfortunately the Dac doesn't allow you to shiftin data to test whether the shiftin/out commands work with the ic.I have found the commands work with eeproms but not always with other ic's.Therefore you must write your own.Attached is an example for a Max 1270 A/D.
One more time .I just put VB6 on my pc and it hijacked my extensions.
