Am trying to interface a 16F84 to the AD7391 DAC, but with limited success. I have wired the DAC for unipolar output mode, with a 2.5V reference voltage and I am getting irratic output voltage. Can anyone see where I'm going wrong? Thanks
' AD7391 10-bit DAC evaluation programme
TRISB=0 'portb outputs
DEFINE SHIFT_PAUSEUS 100
'AD7390 pins
sdi var portb.0 ' data pin
clk var portb.1 ' clock pin
ld var portb.2 ' load strobe
clr var portb.3 ' clear
led var portb.4 'indicator led
volt var word ' required voltage
v1 var volt.highbyte
v2 var volt.lowbyte
low clr
pause 1
high clk
pause 1
high ld
high clr
main: volt=0 'set voltage to zero
gosub AD7390
volt=205 'set voltage to 0.5V
gosub AD7390
volt=410 'set voltage to 1.0V
gosub AD7390
volt=615 'set voltage to 1.5V
gosub AD7390
volt=820 'set voltage to 2.0V
gosub AD7390
AD7390: freqout led,500,1000
high ld
pause 10
shiftout sdi,clk,5,[volt] 'msb first, clk idles high
pause 10
low ld
pause 5000
