Pulling port high
Results 1 to 5 of 5
    the_antique's Avatar
    the_antique Guest
    Default Pulling port high
    At this point I feel like a total idiot. I was debugging a very simple program for a 16F870. It appears that the reason the program would not work properly was that PORTC.4 was not going high when instructed. Removing all unessential parts of the code, I wrote High PORTC.4. When I checked for a high state on the appropriate pin, I found it to be low. I changed chips with the same result. I added High PORTC.5 and, of course, that pin went high while PORTC.4 remained low. Is there something special about PORTC.4 on this chip that I missed?
    My code follows:
    ADCON1 = 7
    TRISA.0 = 1
    TRISB = 0
    TRISC = 0
    HH VAR BYTE
    MM VAR BYTE
    SS VAR BYTE
    DD VAR BYTE
    N VAR BYTE
    D VAR BYTE
    H VAR BYTE
    I VAR BYTE
    T VAR BYTE
    Z VAR BYTE
    High PORTC.4
    High PORTC.5
    Any help will be greatly appreciated.
    As i remind thos baby PIC don't have any multiplexed stuff on PORTC so i'll bet on a messy contact or bad breadboard.
    i just hope your code is longer than this.. let's say
    ADCON1 = 7
    TRISA.0 = 1
    TRISB = 0
    TRISC = 0
    HH VAR BYTE
    MM VAR BYTE
    SS VAR BYTE
    DD VAR BYTE
    N VAR BYTE
    D VAR BYTE
    H VAR BYTE
    I VAR BYTE
    T VAR BYTE
    Z VAR BYTE
    High PORTC.4
    High PORTC.5
    Here:
        Goto Here
    the_antique Guest
    Yes, the whole code is a LOT longer. I just truncated it to the bare minimums (except the variable assignments). I still have no idea why that particular port doesn't behave as the others do.
    the_antique Guest
    Yep, I am truly an idiot. I was so concerned that, because I hadn't used the '870 before, I had missed some special feature. Instead the problem was in the circuit wiring with a pull-down attached to the pin.
    Pinckney, Michigan
    Some port pins on PIC's are an open-drain output, and need a pull-up resistor to "make" a high signal. RA4 on smaller PIC's in particular.
    This one has tripped me up before also.
    I havent used the '870, but you can check the "I/O pin diagrams" in the data sheet to determine which pins are "push/pull" (don't need a pull-up) and which are open-drain (need a pull-up).
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. confused problem with interrupt in a working program
    By illuminator4 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 18:01
  5. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
